The Daily PT2 of the White Collection."This Is Not a Project is the it's the family ride lol"
hubert
As with me and Hondas there is always a story.
Short version is,after selling my EG
the MB6  need to go into the shop for Upgrades so I need another car,that had to be a Honda.had to be a civic,had to be an Aerodeck.
Was looking at a few Aerodeck but wanted one that was low cost to run.After reading loads of figures and adds I came across a WHITE Aerodeck just like I found the MB6,buy luck or it was meant to be.
155964_10152244420180487_1016122573_n.jp526065_10152244420270487_1015896109_n.jp63295_10152244420355487_2090184932_n.jpg295764_10152244420655487_1664147607_n.jp46029_10152244420735487_1075779109_n.jpg
this was the one although i would have like a 1.8 the 1.5 Eco Vtech was what I needed,cheap in every thing.
400816_10152066538615487_1554655716_n.jp294845_10152795190370487_1226271325_n.jp
I got the Deck in August 2012 so i had it for over a year without touching it and in February 2014 all this happened.
After Seeing this,I wanted to take it to the next level
599624_10153461129480487_1782059598_n.jp
as usual I had a vision but I want to not mess the the engine.
1470151_10153461145175487_1244672870_n.j
first i need a Vti-s body kit which was hard to find
thanks to Louise Demarco for the for the rear lip and bumper for the Aerodeck and the front for the MB6.
1289831_10153162790095487_1934029542_n.j
then I got the rest if the kit from Adam R Arfiqiue
1549381_10153631059795487_1913028803_n.j
on boxing day i was in my loft spraying
1536741_10153630925085487_1656870135_n.j
1009820_10153630930380487_547391312_n.jp
 then it was time to put the car together
after spraying them in the loft on boxing day I could put them on as it was p**sing down with rain so i drove to Bluewater .
1528495_10153631061190487_1786924876_n.j
1499568_10153631061370487_895297561_n.jp
1457512_10153631061510487_526444284_n.jp
1525419_10153631061635487_1065777319_n.j
1527027_10153631061790487_1879735491_n.j
1526582_10153631061900487_549732310_n.jp
1557695_10153631062080487_808366126_n.jp
The rust was a bit of a problem lol
1536638_10153631062380487_493785867_n.jp
1535402_10153631062715487_33332335_n.jpg1522012_10153631063155487_527466307_n.jp
I had to remove some mud then i put the freshly painted VTI-S Kit on.
1499631_10153631064640487_2053920261_n.j
999917_10153631064725487_1760235790_n.jp
1535528_10153631064865487_355913276_n.jp
1475975_10153631065080487_2015651743_n.j
1526888_10153631065510487_368164938_n.jp
the next day i had to rotate the wheels as I had 195x45x15 on the rear and 195x60x15 on the front which made the front look high lol.
1513280_10153637723075487_1491754204_n.j
Comparing
1526756_10153637723740487_1317390075_n.j
THE WHEELS
next I went down the road about 2 minutes drive from my house to a crap yard
were I found  a set of 5 steel for £40
used this site to find the fitments
 http://www.wheelfitment.net/vauxhall
1897891_10153748158620487_1032062540_n.j
then sent the off for banding
1185477_10153642273905487_984707525_n.jp
next day I did the light and grill
1525670_10153649903865487_730854553_n.jp
the wheels came back in a few days
1016729_10153706832520487_738614144_n.jp
next was the hight, needed low.
I have big plans for the Deck suspension but for right now just needed it low
1888459_10153748172105487_382843229_n.jp
1621741_10153748172155487_1467980613_n.j
 using some shock I have in the house as you do,so I set it up
1510753_10153706832630487_632350105_n.jp
I need a jack and a hand so I went to Adam Rafique ,thanks dude for letting me use your stuff.
1000879_10153706832870487_1658394811_n.j1506737_10153706833205487_524561959_n.jp
1507755_10153718780190487_2055718687_n.j
next was choosing the rubber
1544965_10153721673005487_965944445_n.jp
then the test fit
1509731_10153721675700487_2051380799_n.j
1623381_10153721675865487_208302478_n.jp
1095001_10153721676090487_205208779_n.jp
1622142_10153721676340487_1953004559_n.j
1005365_10153721676550487_1867059297_n.j
now to put it all together
 on the 31/01/2013
the rubber was ready
went to http://www.elitedirect.com/tyres
to get the rubber fitted and yes they do stretch with on additional cost
did some more work on  the rims and tyres and it started p**sing down so i went to Bluewater again
Just go careful with those sleeves dude they give shocking handling. I had a set on my old one briefly. And I mean briefly as in a week and then I put mg shocks in with lowering springs
got some proper suspension coming for the deck,these are just for now
Guest craigblight
Low & Slow should be fine
i dnt drive mine low do alot of back road driving and seems hold up fine. im putting stiffer dampers on it as seem as just uprated dampers and springs
