JayLock Posted February 15, 2014 Share Posted February 15, 2014 Right, I will be quick with my yarn but assistance would be appreciated. I start her up this morning, no issues, driving on a duel carriage way doing 40mph I come to an island slowing down I get to 20mph no traffic I crack on around it but as I put my foot lightly on the loud pedal the revs jump to 4000rpm, but the speed is not there, I find this odd and take her back up the carriageway and return to see if it was a one off and blow me down with a breeze block there it was again, I find a nice layby and sit there pondering the issue, from nowhere the dash lights dim and the revs drop from there usual 750 to 500 then almost a stall before coming back then dropping, I turn all electrics off and the blower and listen to the engine and it sounds like its ok but thrumming intermittently. I had the oil and sparks done a couple of weeks ago and extravagant as it sounds (with fuel prices) I only use the finest V-Power to save adding potions to regular fuel, My Deck is an auto 1.6se, yes an auto, I like it but now I am concerned that by changing the oil I have opened a can of worm like issues, the air filters been done as well and I checked the plugs, there brand new NGK's. so now boffins of the 5! what say you? Quote Link to comment Share on other sites More sharing options...
simpo Posted February 15, 2014 Share Posted February 15, 2014 Only good can come from changing the oil unless u put in the completely wrong grade. Maybe battery or alternator problem get a vault metre on them see wat vaults they are putting out! Quote Link to comment Share on other sites More sharing options...
MB3Matt Posted February 15, 2014 Share Posted February 15, 2014 On 2/15/2014 at 7:27 AM, simpo said: Only good can come from changing the oil unless u put in the completely wrong grade. Maybe battery or alternator problem get a vault metre on them see wat vaults they are putting out!X2 oil change won't harm unless its wrong type. I imagine it will have happened to someone on here at some point, so good luck with finding your answer. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted February 15, 2014 Share Posted February 15, 2014 Is the auto box all topped up etc? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 15, 2014 Share Posted February 15, 2014 On 2/15/2014 at 8:31 AM, KiNK43 said: Is the auto box all topped up etc? This or the dizzy. 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 15, 2014 Share Posted February 15, 2014 On 2/15/2014 at 8:31 AM, KiNK43 said: Is the auto box all topped up etc? On 2/15/2014 at 10:32 AM, NIKH25 said: This or the dizzy.Either of these I'd say! Quote Link to comment Share on other sites More sharing options...
JayLock Posted February 15, 2014 Author Share Posted February 15, 2014 Class Info chaps!! will take a butchers hook, whilst looking into this I found numerous solutions across the world wide wait, Possible oil cap loose Spark plugs fault or gapping issue Leads issue air Intake issue fuel filter, a leads been knocked out from anywhere during oil change the EGR needs a clean the air flow sensor is to the heavens or just damned filthy, (I checked this and am I right in thinking its a sealed mini liquorice torpedo shaped thing? on my last car it was a fairly delicate item in its very own little cage, cleaned that with Halis Electrical spray but the civic seems not to have an entry point more of a thermomemter type of reader). Its getting to much or to little of something As those lovely Americans would suggest its a crap shot, or crab not sure but there we are then, I shall don my best Sherlock hat, and away............ 1 Quote Link to comment Share on other sites More sharing options...
JayLock Posted February 15, 2014 Author Share Posted February 15, 2014 Just been looking over the engine and checked auto box oil, this looks good, clean and red, the grade of oil used was 10/40w and according the cowboy(another story for another time) that did the changes this is the correct grade for it, he looked on euro car parts who of course are renowned for their accuracy and honesty ( yet another story) of course this does not mean it was a good oil but he right grade can be assured, or not? Having just got back from a warming up to check the fluids run, all seems well, I get out and decide to gently move the throttle cable to create the smooth way in which I like to accelerate to the red line, and the whole engine shakes like a Japanese earthquake (too soon?) and the air flowing in seems to stop and then choke a bit, kind of like she's on forty a day..... more to do I think, is the egr valve easily accessible? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 15, 2014 Share Posted February 15, 2014 That sounds similar to what was happening to Krzys' a couple of weeks ago (correct me if I'm wrong dude) which would point to the dizzy. Plug gaps, leads and air filter are all easy to check and eliminate so it's worth doing that first. Quote Link to comment Share on other sites More sharing options...
JayLock Posted February 15, 2014 Author Share Posted February 15, 2014 Now is that the whole dizzy? not replaced one of those is that a mission? I have just ordered a new cap and fuel filter, ooo and some STP oil treatment, dunno why but its only £3.50 so anyway I will take some pic's of the changes when the parts arrive, unless there is a how to I missed? the fuel one I have read numerous times but the disty I have watched on you tube so it'll be a first for me, always nervous about engine maintenance, still parts should be with me Tuesday, is it safe to drive till then? I don't mean like ball of fire into a tree but to the whole engine? Quote Link to comment Share on other sites More sharing options...
