constant live feed and ignition switched live?
Dave
Ok, just a quick one as i don't have time to go through the manual. Anyone know which wire on the MB6 radio harness (the standard one in the car, not the harness adapter you buy from halfrauds etc) is the constant live feed (sometimes known as the "memory wire" on head units) I think it is possibly yellow, but cant remember.
Also, which one is the live switched feed from the ignition?
Ta!
It's the red and yellow you swap when the radio doesn't retain it's memory dude! Hope that's what you mean?
Not sure which ones which though but at a guess I'd say red would be the constant live?
I thought red was ignition and yellow was memory. Either way it's those two wires just put a live tester on them that will tell you which is which
as @Krzys said its normally those 2 wires you swap over if it doesn't hold its memory :D
In my case it's not holding memory because it has no electricity, flat battery again :lol:
  • Dave unpinned this topic
