vtismill Posted July 17, 2014 Share Posted July 17, 2014 I put an sir integra engine into my mb6 a while back but just used standard ecu, The sir engine is slightly higher compression and has 180 bhp as standard so reckon an mb6 map prob isnt the best I wanted to get a p72 but there impossible to get hold of, would it just be better to get a p28 socketed with sir/gsr basemap for breathing mods? Also is it better just having single stage vtec? Coming in at 5.5 like b16's? Thanks guys Quote Link to comment Share on other sites More sharing options...
Darren-mc2 Posted July 18, 2014 Share Posted July 18, 2014 There's loads of p73 ecu's for sale . Or yes a p28/30 mapped would be a better option . Quote Link to comment Share on other sites More sharing options...
Darren-mc2 Posted July 18, 2014 Share Posted July 18, 2014 Are you talking about the gsr? With the nowl intake manifold ? Quote Link to comment Share on other sites More sharing options...
Darren-mc2 Posted July 18, 2014 Share Posted July 18, 2014 Normal* Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 18, 2014 Share Posted July 18, 2014 The B18C will only have a single stage anyway as the hardware is different. I would advise against using on the P9K at all just in case the map is different enough to cause problems with the engine. Quote Link to comment Share on other sites More sharing options...
Grant Posted July 18, 2014 Share Posted July 18, 2014 X2 wouldnt want to use the P9K on a c6 engine .. Get a P72/73 or mapped 28/30 ASAP .. Quote Link to comment Share on other sites More sharing options...
simpo Posted July 18, 2014 Share Posted July 18, 2014 He must had a gsr lump not the sir if he used mb6 ecu 1 Quote Link to comment Share on other sites More sharing options...
vtismill Posted July 18, 2014 Author Share Posted July 18, 2014 Yeah it's a gsr/sir engine not a type r engine, so it's got dual runner intake like the mb6 Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 18, 2014 Share Posted July 18, 2014 Hmmmm not sure really, probably better off on an ECU that was paired up with the engine in the first place, no idea what would happen running it off the standard P9K. That's the only reason I say not to run it with it just in case. Also while I've noticed, can you fill out your profile details please mate? Ta Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 19, 2014 Share Posted July 19, 2014 Is it a b18c1? If so Mb6 map would be Fine.I was under the impression the gsr engine is identical to a C4. Just slightly more aggressive fueling from the p72. But after talking to dynodaze rich ages ago. He said they make virtually identical top end power. 1 Quote Link to comment Share on other sites More sharing options...
