KiNK43 Posted July 28, 2014 Share Posted July 28, 2014 Hey. Anyone got an idea what's gone amiss before I start pulling stuff out or hitting my stereo with a lump hammer.Since changing my gearbox. Which involved disconnecting battery.My kenwood head unit can't keep some settings.Presets are there and it keeps eq settings.It even has aux in enabled which is off by default. But the display settings and key colour settings reset every time the car is started.Anyone had a similar issue??? Quote Link to comment Share on other sites More sharing options...
Chandler Posted July 29, 2014 Share Posted July 29, 2014 have you swapped the red and yellow wires over? this sometimes happens with some stereo's. check all fuses just in case.i dont know what else could have gone wrong :/ Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 29, 2014 Author Share Posted July 29, 2014 Yeah they swapped over. Head unit was in my mb for years and has been working fine in eg for over a year. Best start lookjng at fuses then hey.Thanks Alex. Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 29, 2014 Share Posted July 29, 2014 Bit weird if all you did was remove the battery, don't suppose there's any fuses on or around the back of it? That's the only thing I can think of! Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted July 29, 2014 Share Posted July 29, 2014 It could be the earth on the gearbox. I say this as one of my old cars had a refurbed box and for a few months after it would do all sorts of weird things. I took it to a few garages and it turns out it was when they sprayed the box to clean it up they didn't clean an area for the gearbox earth so it would be on and off with the electrical connection. Worth a look as you have changed the box. 2 Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted July 29, 2014 Share Posted July 29, 2014 It could be the earth on the gearbox. I say this as one of my old cars had a refurbed box and for a few months after it would do all sorts of weird things. I took it to a few garages and it turns out it was when they sprayed the box to clean it up they didn't clean an area for the gearbox earth so it would be on and off with the electrical connection. Worth a look as you have changed the box.^^this i had a similar issue Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 29, 2014 Share Posted July 29, 2014 It could be the earth on the gearbox. I say this as one of my old cars had a refurbed box and for a few months after it would do all sorts of weird things. I took it to a few garages and it turns out it was when they sprayed the box to clean it up they didn't clean an area for the gearbox earth so it would be on and off with the electrical connection. Worth a look as you have changed the box.Good point! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 29, 2014 Author Share Posted July 29, 2014 Cool cool thanks guys. Defo worth a look then.Tbh I ruled it out in my head because engine runs smooth etc. But I will defo check it out.Cheers Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted July 30, 2014 Share Posted July 30, 2014 Mine ran smooth at the time until i hammered it hard around a corner and then it would start spluttering and the cluster clocks would go on and off. Quote Link to comment Share on other sites More sharing options...
Chandler Posted July 30, 2014 Share Posted July 30, 2014 yes, check earthing!! good point @WilkesyMB6i drove mine to my nans which was a good 8 mile trip, was running fine etc, went to leave and it wouldn't start!! the engine was still warm from when i had been driving it!!Honda's do have to be earthed well, which is why i'm using 0 gauge wiring to earth it Quote Link to comment Share on other sites More sharing options...
