Dinochips S2000
dinochips
small add to the sotroy as got to go prep the civic for japfest ina sec.
So I wanted to take a break from fixing stuff and customize a little and the best place to start was the wheels. As they will defo be replaced so I thought painting them wont hurt
took them into work.
masked them up and sprayed them with some high gloss 2pack black
Done
i do like black wheels on a silver car but until I have the fund to get some Works emotions these will have to do :D
( dont keep them for long as you will soon see)
  • 2 weeks later...
SO to power on the thread a little more heres a few more progress shots
during
after
still lots to clean up but will get there in the future.
CLUTCH change time some of the tools needed
It was very cold but we were determind to get it done.
pretty much involved dropping the front subframe 3inches to get to the top gearbox bolts and pulling everything out.
Old clutch was completely dead
so RPC stage 1 clutch went in fine and all put back together in 2 days wasnt muc space to work but thanks to flat mate got it done
few other things that I replaced whilst it was in the air whch i can't be botherd to put pics up of are
Both front and rear track rod arms
front lower wishbones because got some new less rusty ones for super cheap
drivers side ABS sensor and ABS  gear ring
With the car now driving loads better was time to sort the alignment and get rid of the funny wobble when i let of he gas
We found we could only do the front in this session as the caster adjustment had seized up with is very common in s2k's
mid progressIMG_1896_zpswub8hx91.jpg shot of my babies
So the car was pull in a straight line finally but still had a the wobble problem when i lift off.
So decided to change the exhaust LOL
I am not kidding when I say this exhaust was on the car for a total 10 minutes as It was the pure meaning of drone so where did I go next
Japspeed cat back system
This system was alot better but still didnt have the sond i was looking for sooooooooooooooo
DECAT pipe :D  not the best one out there ut it worked and gave he car I nice note t it for now but still go a beter idea i wan to try out.
anyway Back to the wobble issue. I decied to change the tyres. funny enugh I managed to get aset of 17's which good tyres for £130 only issue was the tyres where smaller than i thought which made the car look stupid.
So hoping this cured the wobble issue took it out for a drive and found it made it  worse.
Next thing to attack was rear caster and alignment hoping this was the cause.
SO chucked it in dads work shop and spent the day sorting oout the siezed bolts.
We fixed them by super heating the bolts screwing a wheel nut on the end and using a jackhammer to smashing the Fook out of it until it popped out the other side which worked a treat. IMG_2067_zps7jmc3hqo.jpg
I then spent the rest of the day with the laser alignment tool to set the tracking perfect sorting out this problem. I also replaced all the caster bolts and nuts with new ones and I hate spending £80 on 4 bolts and 4 nuts.
So after a long drive back to london I was rather p**sed the car still wobbled when i lifted off the gas and when it dose it at 70mph it really wasnt fun so the next step was tyres.
I managed to source a set of 4 Perilli Pzero's for a very good price chucked them on the back of the s2k and took it to the garage up the road.
I was so relieved that after a full tyre change and 4 wheel tracking the s2k finally handled like it should which means now I had a base platform to really start improving.
