  • 0
Fuel into Engine oil ?!
Guest Vitor
Guest Vitor
Hi, good evening everyone.
Normally I check the oil of my MB6 almost everyday, and today I decided to see it, and i saw that the oil level as increased. I smelled the oil and it look likes that it smells gasoline.
What is the cause of it ?
Thanks
7 answers to this question
  • 0
It's usually down to worn piston rings, faulty injectors or spark plugs or very high fuel pressure........have a compression test carried out and have the fault rectified before you change the engine oil.
Doing short runs on choke could also be a reason as would lack of servicing.
Hopefully a good engine service will rectify the problem :)
  • 0
Never heard of that before! Dont really see how it can even get in there!
Only way that i could think of is if the rings were gone and it was leaking through.. But that would mean that it would misfire ..
  • 0
Not saying this is your issue.
But I've known this to happen due to injector/ecu fault. I think it was dynodaze rich's supra.
cylinder has become saturated with fuel which drains past rings and contaminated the oil.
Does the engine run ok?
  • 0
Guest vitor
Yes the engine is ok, no smoking,  and its running normal.
Answer this question...
