Viltor Posted September 3, 2015 Share Posted September 3, 2015 Hello everyone, 2 or 3 months ago, I noticed when Im shifting from 1st to 2nd and 2nd to 3rd I notice sometimes some friction. is that normal ? Most of the time its 1st to 2nd and it happens mostyle at low rpm, like 1500rpm or 2000 rpm, is that normal ? someone noticed that ? Thanks Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted September 18, 2015 Share Posted September 18, 2015 Old oil might be brown? But old engine oil is also a dark colour.I would try and find exactly where it is leaking from but a gearbox oil change is always worth doing. Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 18, 2015 Author Share Posted September 18, 2015 Here is a picture how it look likes.. I took the picture from the internet.http://www.hostingpics.net/viewer.php?id=323115gearboxleak.png Thanks Quote Link to comment Share on other sites More sharing options...
0 Dave Posted September 19, 2015 Share Posted September 19, 2015 It's really hard to tell from the pic mate. What might be a good idea is to get under there with a heavy duty engine cleaner such as "Gunk". Clean the whole area and hose/power wash it all off. That way, your starting with a clean base and it will soon be apparent where that oil is coming from. It may be from an old leak that has since been sorted, so best to clean it all up and then watch over a week or so to see where it's coming from. Might also be a good idea to get the levels checked once again, and if need be, change the gearbox oil.It's one of the hardest places to determine a fault, the gearbox. The bent fork I think would possibly show the fault all the time, whether cold or warm. If the fork was bent, then you would get the same problem changing gear all the time. I too would imagine the main fault now to be the clutch itself. How long/many miles has the clutch done to your knowledge? If unknown, then it could be a really old clutch now and may be due for a replacement. I know I had the 1st to 2nd crunch with my MB6, and the new clutch totally solved it. But had the same fault (although more severe, with 1st to 2nd, then 3rd back into 2nd) on my FN2, and that turned out to be 1st 2nd 3rd and 4th synchros totally gone. Did the linkages look ok when you were under there? Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 20, 2015 Author Share Posted September 20, 2015 Hi Dave, the linkages look ok. I also have news, yesterday my clutch fluid looked dark, so I decided to flush it with new DOT4 fluid, since I flushed it, it look like the gears are more smooth and I almost didnt get any crunch from 1st to 2nd. I also noticed that the clutch its bite points has been lowered. PS: my clutch has 198k KM ~123k miles I dont know if its have been replaced or not Thanks Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 20, 2015 Author Share Posted September 20, 2015 Anyway, I just bought http://www.ebay.co.uk/itm/331151240121?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT . I will give news when it arrive and it will be installed. Thanks 1 Quote Link to comment Share on other sites More sharing options...
0 Jayhoath83 Posted September 20, 2015 Share Posted September 20, 2015 Thats cheap for an exedy make sure its a real one as there are a lot of fakes Quote Link to comment Share on other sites More sharing options...
0 Dave Posted September 21, 2015 Share Posted September 21, 2015 The new clutch fluid will make a huge difference, especially if the old stuff looked bad mate. Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 24, 2015 Author Share Posted September 24, 2015 hello everyone, i have a new I dont know if it makes sense but, after driving for a while with no crunches from 1st to 2nd I noticed there is a downhill near my home and most of the times i pass there i get a crunch from 1st to 2nd. could it it possible ? lol Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted September 24, 2015 Share Posted September 24, 2015 Dude, seriously take it to a garage, this is getting no where.... 2 Quote Link to comment Share on other sites More sharing options...
Viltor
Hello everyone,
Thanks
Top Posters For This Question
4
7
25
4
Popular Days
Sep 10
12
Sep 9
7
Sep 3
7
Sep 11
5
Grant 4 posts
Krzys 7 posts
Viltor 25 posts
Gel 4 posts
Popular Days
Sep 10 2015
Sep 9 2015
Sep 3 2015
Sep 11 2015
Popular Posts
Krzys
Grant
Initial suggestion would be an absolute must to replace the fluid. Then go from there
KiNK43
Annoyingly
49 answers to this question
