dr_broon Posted March 12, 2016 Share Posted March 12, 2016 Some propper modding going on here Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted March 12, 2016 Author Share Posted March 12, 2016 Finished the first top, might need further design changes but looks gd so far, test fitting tomorrow! Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted March 13, 2016 Author Share Posted March 13, 2016 First coil fitted Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted March 22, 2016 Author Share Posted March 22, 2016 Other rear shock fitted, took it for a spin earlier, much harder and a bit boucy but i think the reason is the back weighs as much as a sock lol Fronts next week Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted March 28, 2016 Author Share Posted March 28, 2016 Front shocks plated and welded, both have been drilled. I just have to hoefully pop into work to get a drill later to drill the tops and i can fit them! They need cleaning up and painting but will look better! Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted March 30, 2016 Author Share Posted March 30, 2016 Front coils fitted, just need to level out and lower the back a bit. Next is to see if i can get some polybush bar and make some custom bushings for the rest of the suspension! I have no idea if the cambers are right but drove ok so cant be too bad lol Quote Link to comment Share on other sites More sharing options...
dr_broon Posted March 31, 2016 Share Posted March 31, 2016 Lows indeed Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted April 3, 2016 Author Share Posted April 3, 2016 Done a bit on silvia today, removed the passanger door card, bolt the passenger seat, removed the ariel, removed the front bumper and raised the front and lowered the back too. Bolted the plate to the bottom of the beam, think im going to shave the corners in and fix the indicators to those side holes. Think ill bolt a oil cooler to the panel next to the rad Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted April 7, 2016 Author Share Posted April 7, 2016 Started making the indicator plates, not too bad ? Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted April 7, 2016 Author Share Posted April 7, 2016 All welded and grinded flat, just need a bigger drill and i can mount the indicators, a rub down and then paint! Quote Link to comment Share on other sites More sharing options...
