Silvia K10 - wheels fitted!
VTISmichael
  • 2 weeks later...
Front shocks plated and welded, both have been drilled. I just have to hoefully pop into work to get a drill later to drill the tops and i can fit them!
They need cleaning up and painting but will look better!
Front coils fitted, just need to level out and lower the back a bit. Next is to see if i can get some polybush bar and make some custom bushings for the rest of the suspension!
I have no idea if the cambers are right but drove ok so cant be too bad lol
Done a bit on silvia today, removed the passanger door card, bolt the passenger seat, removed the ariel, removed the front bumper and raised the front and lowered the back too.
Bolted the plate to the bottom of the beam, think im going to shave the corners in and fix the indicators to those side holes. Think ill bolt a oil cooler to the panel next to the rad :D
