  • 0
Help needed - 1999 Aerodeck 1.8 VTI - Cuts out when accelerating
Kit
Question
Hello All,
I could really use some fresh ideas.
Situation: Driving down the M4 - car was nice and warm - cruising along steadily. Revs start dropping when accelerator is pressed - pulled into services.
Parked up and let idle, idle was rough, tried to pull away, revs dropped when accelerating - stalled. Re-start, starts fine, revs high then drops all the way to stalling.
Historical problem: Past few months - once the car is warm - then stopped - then started again - it will occasionally hesitate / bog when accelerating - Coil pack?
Car was recovered to a garage I use, they have looked at it and no ideas. They are getting an auto electrician to investigate.
Could it be: blocked Cat? Coil pack? distributor?
Any help appreciated. Cheers, Kit
  • 0
20 hours ago, Dave said:
Does the eml come on when it happens? Could be the ignitor in the dizzy is failing. Quite a common fault the last wee while. Could be the age/mileage the cars are at now.
No eml light comes on. Starts up happily then dies.
  • 0
On 29/11/2016 at 5:57 PM, Kit said:
Hello All,
What was the answer in the end then? :)
Answer this question...
