question about the heater core matrix
hi folks hi wanted to ask if anyone knows where can i buy the heater core for my mb3, i searched on ebay but unfortnetly i cant put mb models in vechile only appear americans ej ek, so immnot sure if they fit or not, and maybe there is somewhere in europe where i can order one new for under 50€ as seen on ebay for ej ek models.
thanks im advance
Link to post
I'd be surprised if it was different to the rover 400 / mgzs one.. But it's not guaranteed to be the same. Would be less of a risk if it were cheaper
https://rimmerbros.com/Item--i-GRID003155
https://rimmerbros.com/Item--i-JEF000080P
Might make finding a second hand one easier though.
One thing I notice is that this one is only for the rover 400 / 45 / Mg ZS and not the 200 /ZR. This makes me think that the ek one will be different from the mb, but again, that's just a hunch.
Would anyone else know for sure?
  • Thanks 1
Link to post
Just thinking actually, it might work out cheaper for a repair by a local auto radiator company if you can find one.. These are some before and after pics of my heater bypass pipe (new one wasn't available).
  • Thanks 1
Link to post
Posted (edited)
Hi there, i made a bypass using the tubes from the car had to cut One just to put the valve functional.the pipe that comes from the side of the motor is connected to valve has normal and after the valve the tubes go directly to the back of the engine where the return from the heater Core was connected... The car functions has normal, There Will be no problems using this in the long Run?
I dont see that pipe you show for bypass on mine...
Thanks man allways helping...
I Will post photos of my repair i made for you to see what i mean.
Cheers
Edited by rickybeau
Link to post
hi do you ever seen the heater core matrix?
i found this on ebay i believe its the same but im eyballing from mine that i only see partially but it looks the same form just want to ask for anyone who has seen one.
https://www.ebay.com/itm/Fits-1996-1998-Honda-Civic-Heater-Core-APDI-47694RC-1997-Heater-Core/292748067866?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111314%26meid%3D49f80047781f4a1f9cd3085a71594b1d%26pid%3D101195%26rk%3D3%26rkt%3D12%26mehot%3Dco%26sd%3D392401386386%26itm%3D292748067866%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseUnbiasedWeb%26brand%3DAPDI&_trksid=p2047675.c101195.m1851
i appreciate any help, i could try and fix mine when i remove it but for the massive work it is to install it i want to put a new one, and also i need the car so when its desmantled i want have transport to go anywhere to repair the core so...
Link to post
Posted (edited)
if i was sure the rover ones worked that was more easy but i am not sure just eyeballing so i might have to forget it... wich is ok till the winter then will be urgent...mmmm mb il, try and solder it when i take it out, will see what i can arrange till then lol
This is my bypass...as promissed might Sparkle someone criativity lol
Edited by rickybeau
Link to post
I've never seen mine too be honest I know Jake @KiNK43 had his out years ago on his old mb6
  • Thanks 1
Link to post
