NOODELS MC2
noodels
yes a long and frustrating day :x
i set at max 48.1=3.3 bar this seems to much [smash.gif]
will try lower at 2.8=41.16 psi if/when i get it running tomorrows :oops:
given 1 bar =14.7 psi :geek:
Tom ^^With the porn window open :lol: wrong forum mate ;)
got a p72 jdm A003 on its way :P and mugen chip kit that needs installing :?
quote:from guy in canada.
has the vtec engage at 5250 which will be a perfect, and revlimit i will have to change it to 8900rpm. :)
So it ups the VTEC point, or does it lower the IABs?
Normally gets rid of the iab,s and ups the vtec point.
:? ^^quote:Normally gets rid of the iab,s and ups the vtec point
Blox Hope not want the iabs left in :lol:
s0 vtec set to come in lil higher so i can make use of the 1st cam stage as its really good atm and do feel cuts in to early and would benifit being higher,hope the secondary vtec cam and + iabs will be more agressive and catapolt me into the another dimension WACK11111
  dr_broon said:
is that from the guy on ebay? seen his ecus a lot and wondered about them / been tempted.
hope it sorts out the probs bud :)
got the ecu uk pvt sale and the chip kit from canada jdmnsx
Brilliant mate that should be fun i have bought a new eeprom burner from Hong Kong would you be interested in my old one mate so you can have a play with some Hex on the chip?
i have been playing with the spoon chip that came with my p72 and its actually pretty well setup think i might use that when i get my new mani decat and mongoose WACK11111 !.
let me know if you need any help mate and get yourself a zero insertion ziff socket so that when you remove the chip for editing you dont bend the legs on the eeprom mate ;) .
Have fun playing.
8-) will be asking you quite a bit me thinks :lol:
sent you pm regarding the burner,will order a zero insertion ziff socket asap ;)
so if i put the mugen chip in socketed board, that will knock the iabs out,
guess depends on what he has sent me i though :idea:
quote:from seller regarding iabs-
Sorry for the delay....Yes its functional.. :)
jimbob told me spoon was not that good so got the mugen one and setting as above for gsr teg, but they are just base maps anyway and once you have that can play around with the map anyway if you have a burner and chrome and stuff ? :?:?
