knightmaric Posted July 10, 2012 Share Posted July 10, 2012 Hey all,I fitted a set of lowering springs to the rear of the car about 2 months ago but i've noticed that the driver's side sits at least an inch lower than the passenger side.Now the only thing I can see different in the two is that i've fitted the passenger side shock the other way around but it fits in fine, I don't see how this would make a difference though.Could someone highlight at all if possible?Here are 2 pictures showing the difference.This is the lower driver's side.This is the higher passenger's side.Any help in regards to this would be great thanks guys. Quote Link to comment Share on other sites More sharing options...
simpo Posted July 10, 2012 Share Posted July 10, 2012 Doesn't the top mount slant on a angle which would mean one side would sit higher? Quote Link to comment Share on other sites More sharing options...
knightmaric Posted July 10, 2012 Author Share Posted July 10, 2012 Just been to the car and taken 2 pictures.By the looks of it both of the top mounts seem to sit at the same angle in the car itself, so I am rather puzzled by it is lower on the one side.Driver's side rear.Passenger side rear. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted July 10, 2012 Share Posted July 10, 2012 Have you got the springs sitting in the shocks correctly Quote Link to comment Share on other sites More sharing options...
james Posted July 10, 2012 Share Posted July 10, 2012 are the springs on the right shocks ??rear rear front frontnot front rear or rear front Quote Link to comment Share on other sites More sharing options...
noodels Posted July 10, 2012 Share Posted July 10, 2012 take spring of and compare hight Quote Link to comment Share on other sites More sharing options...
weetec Posted July 10, 2012 Share Posted July 10, 2012 NIKH25 said: Have you got the springs sitting in the shocks correctly X2.. if its not sat right it will make a height difference. Quote Link to comment Share on other sites More sharing options...
shebabby Posted July 11, 2012 Share Posted July 11, 2012 x3 also count the number of coils on each spring ! Quote Link to comment Share on other sites More sharing options...
james Posted July 11, 2012 Share Posted July 11, 2012 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 11, 2012 Share Posted July 11, 2012 I once fitted a set of springs to a peugeot and had the same issue. It turned out I had been supplied with one -35mm spring and one -60mm spring!See if you can check the part number on both springs to see if they match Quote Link to comment Share on other sites More sharing options...
