RobE84 Posted July 11, 2012 Share Posted July 11, 2012 i am looking at a possibility of tagging along with about 18 petrol heads to the nurburgring for a long weekend of track time...i am loving the aerodeck the way it is now but need to have it a little more track ready... hoping to have about €800 towards mods... i know new springs are needed so that leaves me about €640...what would this best be spent on.... taking into account fuel and accommodation are covered... Quote Link to comment Share on other sites More sharing options...
noodels Posted July 11, 2012 Share Posted July 11, 2012 springs? what sort for 160E eibach would be best £235 , though progresive and not linear type best i recon for deck and best spring quality whats your set up atm ?? Quote Link to comment Share on other sites More sharing options...
simpo Posted July 12, 2012 Share Posted July 12, 2012 I would as mgzs setup plus the mg Rear arb Quote Link to comment Share on other sites More sharing options...
RobE84 Posted July 12, 2012 Author Share Posted July 12, 2012 current spring setup is cut stock springs..... a mate of mine owns icetronix.com and he has a set of 40mm lower spirngs knocking about that have been on display so its a case of mates rates... cant remember the name off hand... and what year mgzs do i need to find to get bits from... and what bits will swap straight over??? is it worth changing the intake and exhaust manifolds and exhaust??? or is that going down the re-map route?? Quote Link to comment Share on other sites More sharing options...
dr_broon Posted July 12, 2012 Share Posted July 12, 2012 sounds like you're in for some fun if you did go eibachs you'll definately need better shocks... for the roads, but massively for track and especiallly the ring - the bounce with standard shocks is scary.if i had my time over, i'd try the koni yellow shocks on the standard springs, but with the spring cups on the shocks on the owest setting so you still get a bit of a drop.. I reckon that'd give a comfortable ride, but much better handling than standard. always gives the choice of upgrading the springs if still needed.wish i'd done the shocks first so I knew - anyone else upgraded shocks but not springs?sorry if I'm hijacking the thread a bit, but for control in bends good shocks rock Quote Link to comment Share on other sites More sharing options...
dr_broon Posted July 12, 2012 Share Posted July 12, 2012 just read cut springs... they'll need changing then.. Quote Link to comment Share on other sites More sharing options...
RobE84 Posted July 12, 2012 Author Share Posted July 12, 2012 UnicyclingTom said: simpo said: I would as mgzs setup plus the mg Rear arbThis with a full exhaust system and some better wheels. A full service is a must, new oil, plugs, filters etc.. was thinking at service performance denso plugs, full service kit and what i need to know is what year mgzs can i get bits from... i am new to the honda scene... my last toy was this: so i just want to make a complete shopping list and start chipping away at it... 2.5" exhaust or 3"... wont ever be going down the turbo route so looking for best setup... Quote Link to comment Share on other sites More sharing options...
james Posted July 12, 2012 Share Posted July 12, 2012 brake pads at least id say even skim the disks Quote Link to comment Share on other sites More sharing options...
noodels Posted July 12, 2012 Share Posted July 12, 2012 dr_broon said: just read cut springs... they'll need changing then.. good pads/discs mgzs 180 suspension geo set 2.5 mani 4-1 or 4-2-1 or 4-2-2-1 try yor get good adjustable damper spring and arb rear Quote Link to comment Share on other sites More sharing options...
james Posted July 12, 2012 Share Posted July 12, 2012 noodels said: dr_broon said: just read cut springs... they'll need changing then.. good pads/discs mgzs 180 suspension geo set 2.5 mani 4-1 or 4-2-1 or 4-2-2-1 try yor get good adjustable damper spring and arb rearimo most inportant no.1 good pads/discs 2geo set3mgzs 180 suspension about 400 quid petrol i wonder Quote Link to comment Share on other sites More sharing options...
