Civic EG B18 Boosted REBORN UPDATED 28/01/2016 :-)
10000rpm
It must be all those mb's he is breaking ;-) So how much power is she running?
LoL plenty off 282s I am shocked how good these are with the ds2500 pads but drilled and grooved discs are no good as mine have started getting hairline cracks in them.
Power this made was 310bhp @ .5bar full boost by 3.5k :D:D graph will be uploaded over the weekend.
A few more updates
Walbro fuel pump
Please Help!
Do you have to reverse polarity using wires and plug supplied ? as mine dont pump,only 10psi of air/fuel wtf have i done wrong [smash.gif]
as these means taking tank out again as well to check :x
i fitted this one
http://www.ebay.co.uk/itm/150660845177? ... 1439.l2649
A few more updates
Walbro fuel pump
Please Help!
i fitted this one
The oem connector plugged straight on to mine so i dont think its reverse polarity. Have you connected them the right way round??
How do you know its 10psi? Do you have a fuel pressure gauge??
Used oem yes just pluged it in,got a gauge on it yes >.
had it runing when i fitted it with good psi but was very rich,so i ajusted fpr,think c**ked plugs up so cleaned them, may be c**ked lambda up too, so maybe bad signal to ecu :idea::?:
maybe i should do a bridge service conector test :idea:
