Speed Equip Aerodeck Vti-s **Breaking complete car ** 02/18
10000rpm
Sounds a good plan i will look into it after christmas is the deck running ok did you end up changing the water pump?
i did full major service last weekend changed belt and pump and tensioner just to be safe all the parts were original honda ones i took off it was on 94000 so thought best the belt was in a bad way.
  garymcc said:
Is the 96 spec ITR wheel just a straight swap mate no modifying needed at all?
Thanks as was looking into it and the 98 but thought steering rack etc needed changed.
The only thing you have to do is cut the positive connector (horn wire) and make a brass shoe horn to connect it up to and bolt it up and away you go. Will try getting a pic later.
if you do maybe put up a how 2 thread with pic's and details on how to install and dc2 wheel? :idea::idea:
Definitely a good :idea:
  • 4 weeks later...
Been very busy on the EG and other bits not really had time to do much on the deck.
Just had the M.O.T done and went straight through. Done a full service and changed the rocker cover with a yellow one with carbon plug cover and mugen cap.
Here goes
More updates very soon
