VTISmichael Posted December 8, 2013 Author Share Posted December 8, 2013 Well ive worked out its not the coil, the spark is getting to the centre button in the cap but isnt sending the spark to the ht leads. So I tried putting in the rotor arm in the cap and turning her over and that gets the spark to the ht lead but when the rotor is on the unit it doesnt work!So its either the rotor arm or the distributor unit hmmm very strange... Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 8, 2013 Share Posted December 8, 2013 Sounds like you've got it localised though! I reckon it could be the cap itself? Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted December 8, 2013 Share Posted December 8, 2013 on a car of this generation are the cap and rotar arm really cheap to buy, if so must be worth changing both as from what you say it is pointing in that area... Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 8, 2013 Share Posted December 8, 2013 On 12/8/2013 at 4:28 PM, Mr Brown said: on a car of this generation are the cap and rotar arm really cheap to buy, if so must be worth changing both as from what you say it is pointing in that area...Should be cheap enough, did plugs and leads, fuel filter, back box, centre pipe and a CV boot for about £100 Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted December 8, 2013 Share Posted December 8, 2013 If you say when the rotor is in the cap the spark is firing to the leads, then that would point away from the cap and rotor and more to the actual dizzy. Having said that if the cap etc are only a few quid it would be worth changing them to see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted December 8, 2013 Author Share Posted December 8, 2013 The caps are around £10-20+ depending where get it and the rotor is £2! i tried my old cap and nothing, the fact i put the rotor arm in by hand and i get a spark means the cap is fine. i tried putting a washer inside the rotor arm hole to push it out, that didnt work. Next i had a look at the plate on the rotor arm and there is movement but i pushed it all the way out and nothing sooo i could be the rotor arm! Im ordering a new one now and searching for dizzy unit now, only decent ones i can find are from the U.S which will take time. Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted December 10, 2013 Author Share Posted December 10, 2013 The old girl not going anywhere Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted December 10, 2013 Author Share Posted December 10, 2013 Well today's proding didnt get anywhere, got frustrated and took the whole distributor unit off, it looked ok but i can see rusty parts behind the plate inside. I rinsed it out with wd40 and reassembled and still no spark! So its got to be something in the distbritutor i think, looking for a recon/new/ gd condition one, ive seen ones from £500 to £150! but the cheaper ones are from the U.S, 24-7 spares has one for £168 delivered but i dont know if its new or even the right one, calling them tomorrow. Quote Link to comment Share on other sites More sharing options...
VTISmichael Posted December 11, 2013 Author Share Posted December 11, 2013 i could try earthing the distributor but thats what could be the problem thats its earthing out inside. Its just a headache but ill fix it. Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 11, 2013 Share Posted December 11, 2013 You'll get it sorted dude! Just make sure the parts are suitable for an A20a2 when ordering, though you can double check which engine yours is on the bulkhead but I'm pretty sure it's the same as mine! Quote Link to comment Share on other sites More sharing options...
