Temp gauge issues
vtismill
Yeah the heaters go cooler pretty much as soon as I start driving it not all the time though, bled it for ages with cap off yesterday, I've got another thermostat a gates one so think il fit that and have another bash see what happens if it still isn't fixed I'm well and truly lost!
  • 3 months later...
Still havnt got this sorted, now gets up to temperature ok, fan kicks in fine, as soon as I vtec it though gauge goes right down, is this just because its been really cold recently and it's forcing really cold air in? if I drive normally again it will get up to temp ok again, so new stat i put in I think has cured that, it's loads better then before, just tends to drop after hard acceleration, wish I could get it sorted, so just wondered if anyone else's did this at all really with it being cold weather all the time? Thank you!
I don't think it should drop noticeably, it will drop a bit from sitting still (eg. in traffic) to having air pushed through the system at a high rate but should hardly be noticeable.
Could be a water pump problem.
