Krzys' MB6 VTi-S - Sold!
Krzys
Looked excellent with those on mate but was a tad too close as you said you rubbed a few times so up a little bit and it will be a win
Found out today after taking the wheels off to lift that it was only the outer egde of them! So just the width of the rubber causing the rubbing! Lifted it 10mm today anyway, still looks awesome I think! :D
So the pictures of how it went on Saturday and then some of the "raised" height if you can call it that and a whoring shot or three!
The story goes that out of the box, they are set to their lowest! 100mm drop I think! Couldn't even get the car off the ramp! So lifted it by 30 or 40mm straight away to get us going! Now lifted it another 10mm because of the scrubbing until I get the correct size tires sorted!
54B25F9F-8C4B-4A8B-B86C-0D519574F2D8_zps
243B11C6-E8FA-4E82-97E1-FB4828A477B6_zps
CFAAD384-1636-42E7-AC26-8E52F588A7BB_zps
0E04601C-0B06-4B32-8336-22464CFDD984_zps
3333DED3-3751-486A-84F4-BA7F850F376A_zps
9D269CB3-C933-4EE5-A5A6-AB26FE2C642E_zps
60AE62E0-F143-4888-80A3-52200C5B8EDD_zps
A99D6149-5B03-4FE4-BFB7-3660DD27AFB6_zps
D1039281-9F9B-48BD-904C-AE64516F0585_zps
AD83764D-3352-455F-8866-A93E1502ACCE_zps
D6ACBF99-A51F-4EDA-9CC4-F705B2D9B69C_zps
E8634765-B9BB-4A74-AD0B-97B83FB24F9E_zps
81C5E6AD-5E8C-4FFA-A387-95A908DE11C7_zps
329CADC8-02AC-4311-8FFD-68EF6C1C18A4_zps
F31C469C-2C67-475C-9F63-6775ECE406ED_zps
01F6942C-862E-43D4-A343-6B3DC3B24676_zps
2044B53D-204F-4B84-AD8D-7FF5EBC065B8_zps
A05EF116-389D-43B7-87C5-B5547630E170_zps
350E3D05-1BCD-4EC5-8DE8-0991DB80D2C2_zps
755D1EDA-428A-4D42-947D-9D7D14D983AD_zps
A3AC00BC-A145-4A49-982E-A9998451C9FB_zps
1B9B829E-F69B-45A7-8CD6-55471D8A79F0_zps
4605179B-044E-4A81-9F77-5D30C486C26B_zps
29744D7C-4BD3-4B68-81E4-A0385D4BC6B6_zps
Think one of my front brakes are binding, could hear something rubbing on the short drive after raising the car! Sound changed with braking too.
Still looks awsome at the new height mate, brakes should be a nice easy cheap fix though im sure
Cheers dude! Yeah I'm not worried about them, wear and tear!
That is low mate. :D What size are the tyres, it looks like it says 215/45, is that right?
You must be right about them being supplied on the lowest setting, I think I said to you the other day I had the same problem where I couldn't move the ruddy thing. :lol: Learnt when it came to the rears though and adjusted them up and wound them down once they were on.
Looks almost identical to mine in this.
