vtec2011 Posted November 30, 2013 Share Posted November 30, 2013 I am looking into getting a de-cat as the cat smells like rotting eggs But I also want to add a bit of noise... Problem is the cat is bolted onto the exhaust manifold and I don't know if the dimensions are the same as the cats on the exhaust under the car. Mine looks like this... Thanks for looking! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted November 30, 2013 Share Posted November 30, 2013 To decat d series with those cats. You replace the manifold with stainless one and a normal decat I think. Quote Link to comment Share on other sites More sharing options...
philgor Posted November 30, 2013 Share Posted November 30, 2013 right, the mb3 (1.5) has an eco function, and require's the cat to get hotter quicker, hence why it was mounted on the manifold as a one piece design, where as all the other civic engine's exhaust's have the cat mounted under the car after the manifold to de cat it from what I remember, to decat it you just swap out the manifold for a normal manifold (standard or stainless manifold) im not sure what effect the removal of the cat would do to the engine management system. as for fitting a manifold, this could be the tricky part, you may be able to get away with just fitting a new manifold and adjustable de-cat, or it may end up replacing the full system.... Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted November 30, 2013 Author Share Posted November 30, 2013 Thanks guys! I thought there was a good reason why the cat is located in the engine bay (I bet it cause some heat in their though ) It's probably just easier to get a 4-2-1 manifold then. Hopefully the 4-2-1 can connect to the existing center pipe too. Problem is I don't like the idea of swapping the cat/mani back over just for the MOT. Mmm... think I will have to work something out. Fun times haha Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted November 30, 2013 Author Share Posted November 30, 2013 Sports cat. Ah yeah... Didn't think of that! I hope sports cat for d-series engines exist! Quote Link to comment Share on other sites More sharing options...
spudley1988 Posted November 30, 2013 Share Posted November 30, 2013 When I had my mb3 I got a 4-2-1 for the decat and then went to my custom exhaust place and got a De cat pipe for centre section where they usually are. I got a De cat pipe made up to the same size as an ej9 civic one and sourced myself an ej9 cat for mot time. No warning lights came on and car drove like a dream. 1 Quote Link to comment Share on other sites More sharing options...
simpo Posted December 1, 2013 Share Posted December 1, 2013 Make sure you source where ur O2 sensors are and buy the correct mani Quote Link to comment Share on other sites More sharing options...
DAVEMB2 Posted December 1, 2013 Share Posted December 1, 2013 Have a look. At my trin2 (mb3). I am running a japspeed 421 mani for d series and the a mongoose full system you will have no prob with cel light coming on well I never had lol 1 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 1, 2013 Share Posted December 1, 2013 You only will only ever get a cel on if the car has pre and post cat lambda sensors. 7th gen civic onwards. Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted December 3, 2013 Author Share Posted December 3, 2013 Thanks for all the help people! Guess what, a friend of mine gave me a standard D16Z6 manifold which has no CAT. It looks like it can bolt straight onto my MB looking at it roughly (it should fit as majority of d-series parts are all interchangeable) So I ordered a new gasket set which only cost me £7.42 and fingers cross it will fit to the center exhaust pipe! If it doesn't fit, then oh well.... the manifold cost nothing and the gaskets are ready for a 4-2-1 manifold at a later date! Hopefully it will free up some more horses and more noise in a next few days! Quote Link to comment Share on other sites More sharing options...
