raymb6 Posted December 28, 2013 Share Posted December 28, 2013 well all is not well with my civic when I got my mb the spare wheel well was full of water so I dried it up and put it down to having open boot as it was parked for a year but now I have the same thing happening but its starting to p**s me off as all the windows are steaming up and not in the way I normally expect them to and I have beads of water running down the inside of the windscreen also just wondering has anyone else had the same problem I have noticed that the sunroof seal doesn't seem to be sitting right but there is some water inside where the blind is and iam thinking there shouldn't be Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted December 28, 2013 Share Posted December 28, 2013 Our cars are prone to leaks there are quite a few places they are known to leak from.. The ones i know of areAt the front sunroof drains, worth checking they are not blocked. Windscreen itself. At the rear the boot seal is common for leaking, check it is all in place properly or it may be perished is she sat around for a period. Light cluster seal, they are prone to leaking through this but easy to remove and investigate further Im sure other members will tell us of other areas i have missed but hopefully you got a few places to be getting on with investigating further for now... Quote Link to comment Share on other sites More sharing options...
raymb6 Posted December 28, 2013 Author Share Posted December 28, 2013 serious I didn't realise there was that many leaks mate ill have to have a look next day thanks for advise and to make it worse my heater only works on 2 highest settings id say the resistor is gone Quote Link to comment Share on other sites More sharing options...
beastgtir Posted December 29, 2013 Share Posted December 29, 2013 you can get the resistor for £5.55 off ebay delivered. Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted December 29, 2013 Share Posted December 29, 2013 as above mate although i paid £7.50 each myself so not much difference and easy to fit as well.. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted December 29, 2013 Share Posted December 29, 2013 On 12/28/2013 at 11:43 PM, Mr Brown said: Our cars are prone to leaks there are quite a few places they are known to leak from.. The ones i know of areAt the front sunroof drains, worth checking they are not blocked. Windscreen itself. At the rear the boot seal is common for leaking, check it is all in place properly or it may be perished is she sat around for a period. Light cluster seal, they are prone to leaking through this but easy to remove and investigate further Im sure other members will tell us of other areas i have missed but hopefully you got a few places to be getting on with investigating further for now... I think that pretty much covers it, the only other thing I can think of is the roof gutters sometimes get blocked but thats usually in conjunction with the windscreen seals, worth a look though. Quote Link to comment Share on other sites More sharing options...
raymb6 Posted December 29, 2013 Author Share Posted December 29, 2013 cheers for help lads ill have a look when the 100mph winds disperse and rain stops might be in for a long wait Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 30, 2013 Share Posted December 30, 2013 On 12/29/2013 at 9:29 AM, NIKH25 said: I think that pretty much covers it, the only other thing I can think of is the roof gutters sometimes get blocked but thats usually in conjunction with the windscreen seals, worth a look though.I did my sun roof drains yesterday, both had blockages to an extent, went back out this morning and mines still leaking but not as bad, screen and roof gutters are next to check/seal! 2 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 30, 2013 Share Posted December 30, 2013 I think the windscreen is a weak point on these. Doesn't seem to be bonded all the way round instead some foam pieces used.So yeah roof gutters off and windscreen trim. And tiger bond round the top of the windscreen. Hopefully that may help. As Im sure some of you know. This was the death of my my. Caught it late and the water had been running into the foot well a long time rotted through the inner sill. Inner arch too. It's very difficult to repair as there's so many layers. Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 30, 2013 Share Posted December 30, 2013 On 12/30/2013 at 12:23 PM, KiNK43 said: I think the windscreen is a weak point on these. Doesn't seem to be bonded all the way round instead some foam pieces used.So yeah roof gutters off and windscreen trim. And tiger bond round the top of the windscreen. Hopefully that may help. As Im sure some of you know. This was the death of my my. Caught it late and the water had been running into the foot well a long time rotted through the inner sill. Inner arch too. It's very difficult to repair as there's so many layers.Is the trim on the roof gutters easy to lift? Quote Link to comment Share on other sites More sharing options...
