Turbo kit
MB6IX
Yeah that will always be quite the decision! As I would put myself in the noob category I'd play it safe and go for more expensive stuff! Shame I lost contact with a lad local who had built himself a boosted C4 in an EG!
Well you should find him again !! lol
There are an awful lot of boosted c4's on CL .. Can nick some theories etc from them ..
Its all about research and then knowing what it is you want i think .. If for example, what i think by what you've said you want, i wouldnt really see the need to spend 3k for a setup only to run 7-8 psi that capable of much much more .. Little over kill isnt it??
If your just wanting to incrase by 20% then a budget build might well be the answer ..
Yeah I see what you're saying dude! Could end up bolting the snail on and necessary hardware to make it work and it may not need much more than more regular oil changes to keep it happy! 250bhp I would be happy with, probably make more from what I've read though! Suppose if it goes bang at that point I could look at updating bottom end parts for the retry :lol:
That's the sort of build I'm looking into mate :-)
Thing is, I'd think your like me in as much it's not going to be driven hard all the time. Not dragged or tracked regularly. Just the added "poke" for the open road ;)
You think correctly mate! Usually pot about to work on the days I do use it or I'm local anyway and with the this place is wired you won't get away with hooning in the City much so it's more for the open road getting up to speed a bit quicker ;)
Even if your running 7-8 psi. Waste gate is letting out at 8 psi but turbo is still winding up to and producing max pressure. Don't think 250hp would affect the reliability of the engine itself much if tuned well and cooling took care of. Obviously a cheap turbo and affiliated bits may end up dieing a death if driven daily. But kinda to be expected. I think that's why racetech use td05 because it proven in the EVO etc. Obviously mitsubishi have to offer a warranty on an engine that's likely thrashed and not cooled down etc.
When you say about the turbo still making max pressure Jake, I thought the whole point in the WG was so that it didn't? Or have I mis understood??
X2 your eg would be a complete animal boosted.
