stephens mb2. d15b vtec turbo project. :) ongoing....
stephen English
You have a D15B JDM block with 137mm rods, right ? If yes, It should be the opposite - higher compression. D15B and D16 use the same 137mm rods but D15B has 27.X mm compression height pistons (some say it's 27.4, others 27.75) and D16Y8 has 29.3 comression height pistons.
I think you can use D17 pistons if they are cheaper. They have 27mm compression height pistons which should result in slightly less static compression.
If you have a normal D15 block with 134mm rods than D16 pistons won't even fit the rods because it uses different sized rod journals.
  • Like 3
cheers mate.
  • 3 months later...
