- Past hour
- Today
Smaller power steering pulley (hopefully it will clear the bonnet without hacking any big holes in it) and 10% underdrive alternator pulley fitted As we've deleted the AC the factory belt was much too long (think it was something like 7pk1735 from memory). Managed to find a belt that will fit (7PK1400) - it seems ok but apparently there is a mark on the tensioner that you can check - i'll do this next time im with the car to confirm but seems like the right size. Engine mounts ordered - I went for Innovative Mounts for a Civic EG as the price for Hasport mounts in the UK is insane (£700+!) and I wanted to avoid ebay china copied junk on this project... - Last week
Some pics from the show
- 3 replies
- honda civic mb
- chat
(and 2 more)
Tagged with:
Ready for JDM Jam
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
Sure, we paid £700 for ours plus £80 delivery (which I didn't think was too unreasonable to be honest). I think that's about the going rate for one really. It's a JDM import engine from an automatic car - unknown mileage but it should have had an easier life than a UK one. Typically since I've now bought one there's a k24a3 from an accord showed up on eBay for £570! It doesn't look as clean as ours but would likely be just fine.
