  1. Yesterday
  2. Looks mega! That ac delete plate looks alot smarter than the bung I 3d printed haha
  3. Yeah think the alloy suits! In a OEM+ kinda way. Gonna look ace once everything's sorted
  4. Last week
  5. Started getting the bumper fix under way.. It's made out of fiber glass, but the biggest issue is going to be the return underneath that's not really there any more... Should be like this.. So I taped it together in place with masking tape, the duct tape on the back, so that it was all in the right place, then drew around the bottom to make a template of the splitter Waiting for some glue to go off on the wooden template, and haven't had much time after work, so that's probably it for tonight
  6. Shifter mounted properly in car and cables routed. Some hacking up of the console will obviously be required but I should be able to have all the dashboard etc back in Shifter cable plate in place - still needs a bit of work to get the other two bolts mounted and enlarge the hole in the grommet slightly. It's sitting at a less than ideal angle but it was the best placing we could come up with - the DC5 shifter cables we're using are on the shorter side Air con delete block off plate fitted so no huge hole directly into the cabin!
  7. chindeck
    Engine help
  8. Cheers @dan1I quite like the look of the black steelies, but the alloy on the front is from a set of 16s that were on the wife's first accord she had, and I think that looks canny as well. Not sure yet.
  9. That looks awesome! Think the bumper suits with the spoiler. Love it. You got any plans for the wheels?
  10. You can't really tell from the pics how grotty the interior is/was, but it's starting to come up nice. Used some leather cleaner on the seats yesterday and the filth that came off them was amazing. Still need another go and conditioning, but well impressed with how well they've come up. Not sure what to do about the bumper yet, as it's pretty bad with a big section missing... Tempted to go dial it back a bit with the bumper, but it does look cool on the import photos
  11. Some photos from when we got it on Friday..
  12. Yes, it's surprisingly lively when you give it since beans, but it lulls you into pottering about being eco 😁 The new wagon isn't really a wagon at all... It's a k20 (the slow one) It's an auto It's big It's got 8 seats It's from Japan..... It's a stepwagon! Needs some tlc, as its been getting used as a works van by the import company we got it off, and the crazy fibre glass bumper needs fixing from being smashed on an uneven road (probably with the air suspension too low), and the massive rear spoiler needs refitting (maybe...), but it generally needs a really good clean. The paint from the body kit also peeled off when they've took their stickers off.
  13. What's the new project Broon? Any clues lol. The R18 is a decent engine tbh, just need to work it more with the gears. Same engine in my FN1 TypeS. For any fun you need to use the revs, but if just pottering about they are brillant on fuel.
  14. Well, the tourer is no more, a nice chap from Wales bought it, and it's either going to be saved to tow his race eg, or end up as an engine donor for it. Karen's got herself a nice blue R18 fk civic, but it's not any good for family adventures. So we've just got a new project...
  15. Thanks next time i'm with the car i'll measure the hole carefully and find something suitable. I saw those for sale but I wasnt sure at the time if they'd work. I guess the answer is they sort of do! Seems like you can get a bathroom sink stopper that will work without modification that I saw linked here but its chrome - I may get that and paint/wrap it.
  16. dan1
    '99 MB2
  17. Smaller power steering pulley (hopefully it will clear the bonnet without hacking any big holes in it) and 10% underdrive alternator pulley fitted As we've deleted the AC the factory belt was much too long (think it was something like 7pk1735 from memory). Managed to find a belt that will fit (7PK1400) - it seems ok but apparently there is a mark on the tensioner that you can check - i'll do this next time im with the car to confirm but seems like the right size. Engine mounts ordered - I went for Innovative Mounts for a Civic EG as the price for Hasport mounts in the UK is insane (£700+!) and I wanted to avoid ebay china copied junk on this project...
  18. Lovely car! Do you have a link to the wiper delete plug you used? Currently I have a random rubber bung I found in mine (just to stop things getting in when it's parked outside) but i'd prefer something a bit more secure like yours
  19. Earlier
  20. Thanks for the update on the fogs - I managed to get a set of good condition blanking plates so i've removed the fairly rotten big fogs for now but I may reinstate them later. Left the connectors tied up behind. A bit more progress on the K-swap side of things: Drilled a couple of holes in the firewall just under the heater outlet to allow for the shifter cables to pass through (no photo, oops) Got hold of a billet shifter plate designed for an EG but it was sitting too proud of the tunnel so drilled out the fasteners for the shifter base plate and removed it DC5 shifter mocked up - was worried that it would be too close to the dashboard but it seems to just about be ok - the shifter box came with a short shifter already fitted which should help things Clutch and flywheel test fit - just waiting for various missing bolts to arrive from Japan before buttoning it all up. Toyed with the idea of getting an uprated clutch but we've gone with Exedy OEM EP3 clutch for now as it's many times cheaper than an uprated one (£126 vs ~£400) and I reckon it'll be OK for NA power levels. Any future plans to boost the car would require an LSD as well as a clutch upgrade anyway! Flywheel is a Competition Clutch 3.9kg
  21. dr_broon
    JDM JAM
    Some pics from the show
  22. Can confirm these are direct replacement to the existing big fogs. You might need to swap the plug over however. If I remember correctly the front seal wasn't great so I used a big o-ring between the glass and the front screw on cap piece to keep the water out
  23. We get properly ripped off for parts. It always amazes me looking at honda parts from America compared to here.. The dollar price is normally less than the price on pounds, and then you've got the exchange rate to factor in... It's mad. I got some gearbox bits for a fraction of the UK price even with delivery and tax. For the fog lights, a while ago someone fitted these which are supposed to be a good match for the rare big fog lights. https://ebay.us/m/3mKXkv I've had them in my watched items list since, but haven't got them myself as I fitted some big ones from a honda stream.
  24. Haven't had much time recently myself to work on the MB but my father in law has been cracking on with some jobs in my absence K24 mounted up to the engine stand to begin work K20 oil pump cut and fitted. There is a lot of dried up oil "varnish" within the engine so we may run some engine flush and change the oil again once it's running. RBC cam gear fitted (50 degree VTC) - Chains and guides refitted, timing checked. As the eagle eyed may be able to spot - unfortunately one of the oil pump guide bolts rounded off on removal... so after one trip to the local Honda dealer and £7.25 lighter i'm the proud owner of a new guide bolt! (It's crazy how overpriced these small parts are in the UK. They're £1.64 in Japan but of course that comes with a 2 week wait...) Front VTI-S lip test fit - needs painting of course. Currently pondering what to do with the fog lights as they are a bit of an eyesore - one of them has rusted inside and it looks like there's a surround missing. I might just get the blanks and delete them, weight saving (!).
  25. dan1
    '99 MB2
  26. Darius
    Car way too low
  27. You've been a busy boy, love the use of the sink while the boss is out. 😁 those bits are looking good.
