Hondamad1988 Posted September 11, 2015 Share Posted September 11, 2015 Going to rip out the air con on the mb6, the radiator still works but is looking a bit worn on the fins.Thinking of getting a full size rad that goes alls the way across the front grill.Anyone fitted a full size rad? Any fitment issues? What model of Honda rad did you fit? Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 11, 2015 Share Posted September 11, 2015 Once you whip the air con out you'll get much more air into the engine bay and will be cooler than before. My worry would be that a bigger radiator plus all the extra water will weigh more, and you'll lose some of the benefit of taking out the aircon on the first place (assuming that's why you're doing it). Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 11, 2015 Share Posted September 11, 2015 But to answer your question I'd probably look into an integra radiator? 1 Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted September 11, 2015 Share Posted September 11, 2015 Too much cooling unless ur going mental on tuning the engine and tracking it isnt worth the exspence as you wont benefit from it Quote Link to comment Share on other sites More sharing options...
Dexter Posted September 28, 2015 Share Posted September 28, 2015 Too much cooling unless ur going mental on tuning the engine and tracking it isnt worth the exspence as you wont benefit from it I have a Tegiwa stock sized rad and i never have overheating issues even when pushed hard, which in my case means up to 9 hard laps on a 3km course driven to the limit. B18C4 with minor mods. But then again if you're going after the looks, why not ! A wide shiny rad in any bay do look nice... and makes it look a lot faster than it actually is! I don't need a rad for that though, my obscenely loud Magnaflow backbox takes care of that... Quote Link to comment Share on other sites More sharing options...
Grant Posted September 28, 2015 Share Posted September 28, 2015 To say again .. Full width are generally not needed .. Even as a track slag, most will cope with a dual core ally Quote Link to comment Share on other sites More sharing options...
Hondamad1988 Posted October 8, 2015 Author Share Posted October 8, 2015 Fairpoints, I think I'm just used to my old crxs and boxy civics having full size rads, but after your comments I've also thought a full size rad only increases the surface area which will get weathered and stone chipped. Will stick to standard, remove air con and maybe move rad to aircon side to allow better cold air flow to air filter Quote Link to comment Share on other sites More sharing options...
dr_broon Posted October 9, 2015 Share Posted October 9, 2015 Fairpoints, I think I'm just used to my old crxs and boxy civics having full size rads, but after your comments I've also thought a full size rad only increases the surface area which will get weathered and stone chipped. Will stick to standard, remove air con and maybe move rad to aircon side to allow better cold air flow to air filterMust admit I've thought about doing this... It seems a shame for all of that cool fresh air to be keeping the wrong side of the engine bay cool 1 Quote Link to comment Share on other sites More sharing options...
Hondamad1988 Posted October 9, 2015 Author Share Posted October 9, 2015 To be honest it only came to me last night while writing that post, I can't see it being too difficult, the brackets should swap over, not sure if there's a hole for bottom bracket on the other side? Sourcing new pipes and extending the fan wiring will be the hardest parts, those pipes would want to stay away from the manifold! Quote Link to comment Share on other sites More sharing options...
dr_broon Posted October 10, 2015 Share Posted October 10, 2015 I'll have a spy and take a pic of it if you like? Quote Link to comment Share on other sites More sharing options...
