hertsguy Posted December 28, 2015 Share Posted December 28, 2015 Good evening all, I have had my Aero deck about a month now and noticed the other day the front passanger footwell was damp, since we have had more rain it has got progressivley worse...... is there a common leaking point on this model? Thanks guys and girls Quote Link to comment Share on other sites More sharing options...
0 civicturbo79 Posted December 28, 2015 Share Posted December 28, 2015 pollen filter , sunroof drains , badly fitted windscreen . 1 Quote Link to comment Share on other sites More sharing options...
0 Jayhoath83 Posted December 28, 2015 Share Posted December 28, 2015 Or if ya really unlucky there could be rust holes depends on how rust free you are for this 1 Quote Link to comment Share on other sites More sharing options...
0 KiNK43 Posted December 28, 2015 Share Posted December 28, 2015 Mines leaking from pollen filter at the minute. Not had time to investigate furthur Quote Link to comment Share on other sites More sharing options...
0 hertsguy Posted December 28, 2015 Author Share Posted December 28, 2015 Thanks for the advice, Ive checked the sun roof gullies and they clear the water out very quickly. As for the rest i havent had a look yet, the windscreen looks original, will check the rest out tomorrow, The rear passanger side footwell is also wet but unsure if thats just leaked from front to back Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted December 29, 2015 Share Posted December 29, 2015 On 12/28/2015 at 9:25 PM, hertsguy said: Thanks for the advice, Ive checked the sun roof gullies and they clear the water out very quickly. As for the rest i havent had a look yet, the windscreen looks original, will check the rest out tomorrow, The rear passanger side footwell is also wet but unsure if thats just leaked from front to backPossibly, track down the leak in the front first, get the car dried out (dehumidifier?) and see if the rear becomes wet again. Quote Link to comment Share on other sites More sharing options...
0 Dave Posted January 2, 2016 Share Posted January 2, 2016 On 12/28/2015 at 7:33 PM, UnicyclingTom said: Rich!?!!! Long time no see!x2! Good to see you back mate! Quote Link to comment Share on other sites More sharing options...
0 kernowchristoff Posted January 4, 2016 Share Posted January 4, 2016 Hi There Mate I had the same problem. Its the windscreen seal around the A pillers. I had to cut to square in the carpet pulled out all the underlay dried out the carpet got some new underlay and glued it back once dried out. I replaced my seals solved the problem. You can still get them. Any problems drop me a line. Hope that helps. Regards Chris Quote Link to comment Share on other sites More sharing options...
0 skymera Posted January 13, 2016 Share Posted January 13, 2016 Check the drain under the scuttle panel. This was blocked for me and caused water to overflow into the heater vent and be blown by the blower motor. It can also drip out onto the carpet. An easy way to check is to reach under the glovebox, unclip the pollen filter cover and squeeze a finger in . Should be bone dry. In my case, the filter was wet. 2 Quote Link to comment Share on other sites More sharing options...
0 wss97mb6 Posted May 27, 2016 Share Posted May 27, 2016 I had the same problem, removed the scuttle panel by the wipers to find years of dirt. The water was leaking into the air duct for the heaters 1 Quote Link to comment Share on other sites More sharing options...
Question
hertsguy
Good evening all,
9 answers to this question
