  • 0
Skunk2 alpha series 66mm
Viltor
Hi everyone,
I recently bought a skunk2 pro series intake and a alpha series throttle body, im having a problem eith the TB.
The throttle body gets stuck if i gently tap the gas pedal, to go back to hisboriginal position i need to tap the gas pedal and it will idle fine.
Anyone knows a fix for it ?
Thanks
9 answers to this question
  • 0
Good morning everyone,
My problem seems fixed.
My friend lub'ed the TB spring with some WD40, thightned the TB cable and we adjusted the TPS to 0.45 at idle. my car seems to run smoothly now.
Thanks everyone
  • 0
Good morning everyone, well yesterday i did some tests and its the tb stickinging. If my engine is off, the tb is lightly and it opens and closes very easly. When the car is on, the tb turns heavy and inremove the throtte cable and with my hand i notoced some reaistance and it keeps sticking if i gently push the tb and let it. :S
Answer this question...
