  • 0
Hi everyone, just a quick question, will a rim size 17 Inch 7J ET40 with a 205/40 tire fit on my lowered MA9?
Now I have 15 Inch 7J ET35 with a 185/60 tire and it hits the fender pretty quick at the front (when cornering)
Thanks in advance
Link to post
8 answers to this question
  • 0
Hi Mate, think I can se the problem! When new, fitted with 15's, these civics had 195/55 x 15  tyres on them on standard suspension. You have gone up a profile size (so essentially making the wheel/tyre bigger than  it normally is, then lowered it which alters the geometery of the suspension, hence why you're getting tyre rub.
See this guide here >>> FAQ About Honda Civic M's - FAQ - Civic5 Honda Civic MA/MB/MC owners club
To explain things further, and to help make sure you choose the right wheel oiffset/tyre combo, see this link here >>> Wheel Offset and tyre calculator - Brakes and alloys - Civic5 Honda Civic MA/MB/MC owners club
There's a couple of links in there that help explain things better 8-)
Link to post
  • 0
Hi, thanks for the answer, yes the tire is one size bigger then supposed, but ! think the ET35 is also to low, ET40 or higher shut be better.
In fact I was wondering if somebody fitted 17 inch ET40 with the mentioned tire, and lowered of course.
The difference between 195/55/15 and 185/60/15 is only 7.5mm (in total) I don't think that the 3.75mm makes the difference.
Maybe a camber-set is the solution?
I'll take a look at the links you posted, thanks a lot friday.gif1
Link to post
  • 0
I used the first calculator, it's really a fantastic one!, the new size I have in mind is sticking out the same as what I have now, so it will fit (with a minor rubbing but that's only with fast sharp cornering.
Link to post
  • 0
I don't know the answer as such of the top of my head.
However I have been running 15x7 et35. 195 50 15 tyres. And no rubbing or catching at all and the car get driven really hard at times
Link to post
  • 0
195 50 15 is a lot smaller then the 185 60 15 I have, and maybe it's better to put it a bit higher on the springs also, but I like as low as possible.
It's not that much rubbing, mostly in sharp corners because the wheel is sticking out of the fender then.
Link to post
  • 0
@Patrix Is your car lowered by just lowering springs or adjustable coilovers? If its the adjustable one, I'd recommend turning the button on the shock/damper to a stiffer setting. This should eliminate the issue you have when cornering.
Link to post
  • 0
Hi Dave, it's lowered bij coilovers but not adjustable, best thing to do is set it a bit higher, or buy adjustable upper arms, but what i mentioned earlier, it's not rubbing a lot.
At normal cornering it's fine, straight ahead also, only the tight (bumpy) corners will give al little rubbing, it's touching de inner fender (plastic) like a gentle kiss :-D
Link to post
Answer this question...
