btjtaylor
On 6/14/2026 at 7:21 PM, btjtaylor said:
Turns out the handbrake problem was actually user error :oops:
I found a post here that showed me I hadn't followed the correct procedure! Once I did that it was all fine and I didnt need to swap the cables in the end (so I can't comment on the MG Rover ones i'm afraid)
What I can tell you is these parts are the correct length and and do work, but the quality control was a bit suspect (I had to file open the hole in the handbrake cable bracket slightly and file off a bit of badly machined cable that was hang out the end of the pin)
92.10.5233 COFLE 10.5233 Handbrake cable 1655, 1469mm, Disc Brake | AUTODOC price and review
92.10.5234 COFLE 10.5234 Handbrake cable 1636/1449, 1636, 1449mm, Disc Brake | AUTODOC price and review
That's superb mate. Thanks for the link to the cables and also how to adjust it properly. I've also been doing it wrong doh!
Glad you got it all sorted.seeya.gif1
Managed to get the car out into the sunshine today for the first time since October!
I set up the ride height as best I could following some online guides (trying to give maximum "bump" travel) and adjusted the camber using a fairly cheap magnetic gauge, which wasn't the easiest thing to read but did the job, -1.75 degrees at the rear and -2.75 degrees at the front which seems to be a good starting point according to people on the internet who are much cleverer than me! Visually it looks about right comparing to other builds i've seen at least.
Next time i'll adjust the front and rear toe using strings to try and at least get it somewhat in the ballpark. After replacing the steering rack the front wheels somewhat resemble this GIF currently!
a man wearing a helmet and goggles is making a funny face
  • Haha 1
My first time trying a string alignment at home - no expense spared alignment rig built out of 2x curtain poles, 2x builders chalk lines, 4x axle stands, and some rubble bags with white grease in between to act as turnplates! 🤣
It did seem to do the job though. At the very least, it means my tyres won't get shredded on the way to get an MOT and then on any test drives. Stance looking bang on now!
I went to go for a VERY quick test drive and quickly found I couldnt select 2/4/6 gear .. oops. It was working until I swapped the shifter so I think it's nothing serious just a shifter cable adjustment issue. One of these days it will leave the driveway!!
Posted (edited)
Gear issue sorted - the culprit was some badly made shifter cables (they were cheap ones from Aliexpress - you'd think I'd know better by now...)
The cable was too long and not allowing the selector to engage fully. I removed this locknut and wound the cable eyelet further down the shaft and this resolved the issue.
Whilst I would rather have the locknut in place as i'm sure there's a reason for its existence, the cables work fine without them and can't unscrew anyway as they're held on to the gearbox with a cotter pin.
I've found since buying them that these are actually a cheap copy of a K-tuned cable design so it would not surprise me if the quality control was lacking, or they were actually copied wrongly in the first place
A few small minor issues to knock off and then MOT time!! 🤪
Edited by btjtaylor
She is looking soooo good now, sitting perfect. Good luck with the motcmate, I'm sure she'll pass with flying colours. One absolute sleeper that!😎
  • 3 weeks later...
Passed!!! 🥳🥳
A few very minor things picked up:
A couple of tyres were mounted backwards on the rim... that was the guy in the tyre shop not paying attention not me. Easy fix just need to take them somewhere
A very minor leak from one of the power steering lines (I have replaced them all and had the rack out so hopefully just something just needs tightening up)
But considering the entire car has basically been rebuilt by two complete amateurs in a garage and on a driveway, I'll take that as a massive win 😂
The ECU tune definitely needs work as the throttle response is all over the place, but I was only able to tune it for idle and low speed driving up until this point (by driving very slowly around the driveway!). It's booked on for a Dyno session with Jesse (J-Cal) on 10th August so really looking forward to seeing what it makes but going to put some fairly gentle miles on it locally to give it a shakedown before the big day
Edited by btjtaylor
