DeLaSoul
MC2 Project - Chassis prep
Hi guys,
I joined up a while ago to the forum and found a lot of useful info here. Good to know people are keeping the old Honda's alive! I thought as I've gained some knowledge, I'd feedback my experiences as I get into working on my Aerodeck over this next year. If anyone has any questions then please ask, I may take a few days to reply sometimes as my 9-5 take me away occasionally so bear with me.
Plan is nothing too mad, just complement an already cool car that I've had a lot of fun driving on and off the last few years :DUPDATE - that didn't last long lol
Since May this year I have been slowly working on the old MC2, it was my dad's car and it needed a little attention as it didn't get much use this last 2 years or so. It's fairly low mileage and in tidy condition for a 12 year old car, so I hope it's not going to be a total ball ache to work on ;) Like all good projects, start with a clear plan (guess what I do for a living lol) and do everything in stages. Some of these are already complete:
Stage 1 - Brakes - DONE UPDATE - and re-done!!!
Plan is to keep the stock front MC2 282mm based brakes but improve the quality of the discs and pads etc. I will change out all the old flexis and check the lines. At the rear I will look to change the discs and pads also, but the calipers, handbrake cable, discs and pads were done last year so no rush.
Stage 2 - Rear Anti-roll bar - DONE
I keep reading how good an upgrade this is for the Aerodecks so I will fit fro the MG ZS180. Hopefully this will be pretty easy.
Stage 3 - Suspension Bushes - DONE
Old car = old rubber. The car tracks straight but is a little tired. Shame to let it get out of shape, so I want to replace all the bushes where possible for slightly stiffer ones without destroying the ride. Also a good opportunity to get right up underneath and check everything over.
Stage 4 - Shocks and springs - DONE
I don't want to lower the car from stock but I want to improve the handling slightly. After going to the trouble of the rear ARB and bushes it would be rude not to finish off the suspension 8-) UPDATE- Yeap, changed these too
Stage 5 - Refresh the engine
I really like the stock B18C lump and don't really want much more from it. Short term an induction kit, exhaust manifold (already has a stainless centre and rear section exhaust fitted). Long term a complete engine out, strip and refresh but that can wait as it runs sweet at the moment as dad was a bloody good mechanic!
Share this post
Link to post
Stage 1 - Brakes
Gone for EBC discs and pads up front, HEL brake lines all round and DOT5.1 fluid to keep in all in touch.
Front brakes - bit old but still working. Bit of a vibration under braking so I suspect the discs are past there sell by date.
IMAG0014.jpg Excuse the phone image.
Like an idiot I rounded off the head to the screw holding the discs on so I had to cut a groove in the head with a disc cutter and use a bigger impact bit :x
Discs off, new ones on. Clean up the carriers, copper slip and refit
Job done :D
Next - brake lines and fluid:
HEL brake line kit - comes with all new banjo bolts & copper washers and has all the right mounting brackets.
Rear ones installed - afternoons work to fit and bleed the brake system
Brakes feel much better - no more vibration and the peddle is sharp and solid. Just got to bed everything in but car feels better already
Share this post
Link to post
Stage 2 - Rear ARB from the Rover MG
I've read that this is an easy job and well worth the effort. I located one from a MG specialist on eBay with all the mountings and drop links :mrgreen:
Step 1, find the holes! 12 years of crud so I had to clean out all the threads with a thread restorer.
Step 2, mount the brackets - I must admit I had to think about this as even though the brackets are the same each side, they mount with one facing forward and one facing back. Not hard but.....
Step 3, mount the roll bar. Not a simple job on my car as they Powerflow exhaust built on the car didn't clear the roll bar. Off down to Powerflow and ask them nicely to remake the pipe to the back box...
Roll bar now fits under the exhaust pipe and clears everything nicely
I don't like the stock drop links, so I may have to revisit these and find better ones :ugeek:
Share this post
Link to post
put mgzs180 drop links on they better than mb6 ones as they wear and come loose are
coming along mate keep up the good work.
Share this post
Link to post
nice one mate keep it up looking good
Share this post
Link to post
Looks clean that mate, some choice upgrades too :D
Share this post
Link to post
Awesome, is exactly the same as mine and has or is panning to have the same upgrades I want !.
Where did you get the HEL lines from as that is one of my next upgrades, do you have an exact link ?
Share this post
Link to post
Hi guys,
Thanks, hopefully it will turn out good in the end.
@noodles,
I believe the drop links it came with are from the ZS180 but I don't like them tbh. A piece of hexagonal bar, 4 rod ends and a lunchtime in the workshop will have it sorted :geek: I will try the ones it came with though. The car is still in the air while I sort the rest of the suspension parts I want, so I haven't tried driving the car with the roll bar fitted
@stoatman,
I got them from:
http://www.brake-lines.co.uk/honda-civic-aerodeck-mc2-1-8-vti-1998-2001-hel-brake-lines.html
Probably not the cheapest place but I had them next day and after speaking to them I had confidence I was getting the right bits & they are well made with the right brackets for a direct fit.
Share this post
Link to post
Suspension -
Quick update on the progress so far, the rear suspension is finished and just have a few bits on the front to do before I can put the Aerodeck back on the ground and get the tracking done. All the suspension had to come off and the long job of sorting all the bushes, links and bits began :roll:
I bought the Energy Suspension full kit for the car (well the Civic EG kit, same suspension) and laid it all out to check everything...
Rear suspension - Plan to replace all the bushes, upper and lower arms, shocks and springs! ARB is already on now the exhaust clears the bar.
Old LCA's looking a little tired. Rubber in the bushes is in good condition, but it is just starting to peel away from the outers all around the car. Nearly all the bolts came out pretty easily, all except 1 which took most of the day to remove :evil: Angle grinder to the rescue!
With that done the rear was ready for new shiny bits...
New LCA's from the EG Civic - using the old bolts just to check the fit....
The trailing arms also needed a refresh :(
Out with the old bushes, check against new ones...
New camber links, gone for adjustable ones so I can fine tune everything :geek:
Okay, maybe a little OTT so far but I want my Aerodeck to be just right. Quick test fit while I was waiting for a few more bit and bobs.
Old toe compensators...
Cleaned, old bushes drilled out and new ones installed. Bit of a theme going on here :D
Time for new shocks and springs. Decided to go for the Avo GTZ setup front and rear. They are up in Northampton and if i need any advice/support they are on the end of the phone. They are also fully serviceable, and with all the race/rally stuff behind them they should be good. New top mounts from Honda, bushes from Energy Suspension..
Lots of packs like this went into the build - and lots of copper slip :lol:
Time for final assembly on the car. This was a ba$!&£D of a job single handed but not impossible :|
ABS wiring - I had to attach this via cable ties for now
Been a busy few weekends work but getting there! I have 80% of the front done. Just need to pickup the new front upper links and I can assemble everything so I should post an update after the weekend.
Dave
Share this post
Link to post
i take my hat off to you
top job
Share this post
Link to post
fooking gud job mate as above take my hat off 2
Share this post
Link to post
Sweet deck! Loving the mods/resto project, and as above, fair play to you for doing all this yourself mate! This is the kinda thing id love to do to my mb6 when the time comes for the bushes to be replaced. That'll be so tight when its finished, will feel like a new deck to drive!!!! Nice one!! 8-)8-)
Share this post
Link to post
Very nice! Is there a website that yuo can order this stuff from? I really need to get myself some adjustable rear camber arms
Share this post
Link to post
Nice deck you have got there dave hat's off to you for doing all the work your self mate and keep up the hard work and update's coming 1"£££$££"
Share this post
Link to post
8-) great progress mate, considered energy motor mount inserts yet they work ok, a week point on the torque mounts
or you got something else in mind?stops judder ect mb/mc2 prone to it.good idea to check them out , see condition of your OEM ones :idea:
Share this post
Link to post
Hi guys,
Wow, thanks 1"£££$££"!!
I have a few more bits coming this week so I can finish off the front suspension this weekend. I can post up some other updates later today on the smaller jobs I've been doing to get the car finished - I just need to find all the pictures.
@SteveMB6 - I've just been looking at tuner companies after looking at some of the Honda tuning mags from the States - it seems there is a massive tuning scene over there for Honda. Once I worked out what I wanted I searched around the UK for suppliers, but so far Hond-R in Abingdon (camber links, LCA's and bush kit) have been a good source of parts. The rest has come from Honda, local motor factors, direct from manufacturers and few bits from eBay.
@ noodels - Yeah I bought a set of those but my NS torque mount is shot to pieces so I have 2 Integra DC2 mounts on order to replace both sides. I will try them first, then drop in the Energy suspension bits. I was thinking of getting some billet machined mounts but a lot of the reviews I've found say they make the engine vibration through the chassis quite harsh and I want to be able to use this car comfortably.
Dave :D
Share this post
Link to post
Tea break so time for some more pics....
First job was change out all the old earth leads around the engine bay. Can't remember whose build thread I saw this on (sorry) but it looked like a really good idea so I set to work on that...
Repeat around engine bay.
Next, cleaned up the cam cover following the guide in the "how to" section... 1"£££$££"
The car kept cutting out, at first I thought it was random or something to do with the new earth leads but then it started to do it if I started the car quickly. Turned out to be the ignition switch was worn out, Honda told me it was a common fault so off with the steering column covers...
New ignition switch...
and great, the car won't start at all now :evil: Call to Honda and ask if I need to have the alarm reset and they say "no, shouldn't do". Check the alarm wiring and sensor unit around the key barrel and no loose wires so I pulled the new ignition switch off. Wiring was different :evil::evil: Apparently there are several variants of the harness for Auto's, manuals etc.
Pulled the plug apart and re-wired it to work. Car started first turn and stayed on :D
Exterior: No idea why but dad removed the front lip and threw it away. He also removed the front fog lights after getting a price from Honda to replace one of the lenses. Search on eBay found a guy breaking one in Titan Silver :D
VTi lip and fogs ready to go on.
Dave
Share this post
Link to post
intresting plate !! :twisted::lol:
ps there is rear mid/lower rear splitter available poss titan? :idea:
Share this post
Link to post
Did you make the earth wires yourself or buy them? Rocker looks well!
Just noticed its got an NI reg. Did you buy it from there?
I see you also have a green vti there too, any mods to that one?
Share this post
Link to post
@ SteveMB6 - I think the thing to look for on any parts is quality vs price. I would look for any reviews on forums for a product as a starting point. I know that the ones I fitted were quite expensive but I've seen some good reviews and Skunk2 are as far as I can tell a trusted brand. I did a similar project a few years back on my old ST162 Celica and learned the hard way on some cheap bits so now I tend to go on trusted parts only.
I made the earth leads myself. Whole engine bay cost £20 using audio cable and gold plated connectors. I soldered and crimped the plug on for a good solid connection. The difference was noticeable at night with the A/C and lights on at idle, no more dimming headlights. The plate is a private one, the car is a UK not an import or anything, it's just a way of hiding the cars true age :D
The MB6 is my brothers car, completely stock. He's more into old Toyota's, the Civic is just his run daily driver.
@noodels - I can PM the guys number over. He had the Mid spoiler for sure when I was there on Saturday, not 100% on the rear skirt but I think so. All in Titan silver :) He's based down near Slough and had a few MB6/MC2/DC2 bits.
Share this post
Link to post
cofusion.com , got them already mate!! was just need sills the guy is halifax location location :0)
perhaps your guy is another ?oh well dont need them as above.. 8-)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
