DeLaSoul Posted April 3, 2018 Author Share Posted April 3, 2018 Doesn't look like the last picture of the decal loaded so I'll try again Had to do a little bit of work on the roof to get it ready to fit. I had several coats of UV resistant lacquer put on it but it had a few defects. Decided to smooth them out before fitting, easier place to get water while sanding was in the bath Secure from the outside first... Then from the inside to check its alignment Had to mask the roof off to make sure I didn't get the sealant everywhere but the alignment still wasn't right Simple ways are often the best While the inside was secured an easy way too. You'll notice the aluminium blocks on the inside of the roof. These have been bonded and bolted to the carbon and drilled and tapped on the underside. I'll make and bolt 3 braces inside that will hopefully stop the roof from being pulled out by air pressure at speed. Then taped up the inside gap to stop the sealant dropping through Hopefully it will all be bonded in the next few days but this stuff was going off before i was finished! Not going to remove the clips and tape until Thursday just in case though, and then see if it's stiffened the roof. If not, I've got a plan to sort that later.... 2 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted April 4, 2018 Share Posted April 4, 2018 That sunroof bung looks tip top! Nice to see the DOHC stickers back on her as well 1 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted April 4, 2018 Author Share Posted April 4, 2018 5 hours ago, dr_broon said: That sunroof bung looks tip top! Nice to see the DOHC stickers back on her as well Let's just hope it stays in place! I checked the sealant when I left for work and it's almost set so 24hrs should be about right. As silly as it sounds, it's starting to look like a Honda again with the stickers back on. I may scan and make the rear badges as stickers to see what they are like 1 Quote Link to comment Share on other sites More sharing options...
Chandler Posted April 4, 2018 Share Posted April 4, 2018 cracking work again mate 1 Quote Link to comment Share on other sites More sharing options...
Blackwolf Posted April 28, 2018 Share Posted April 28, 2018 hows this coming along? Quote Link to comment Share on other sites More sharing options...
T799 Posted April 28, 2018 Share Posted April 28, 2018 What an awesome project! Will be following this one for sure. Good luck with the build mate! Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted May 1, 2018 Author Share Posted May 1, 2018 On 28/04/2018 at 1:54 AM, Blackwolf said: hows this coming along? I was on holiday for a week but managed to bring some parts back with me On 28/04/2018 at 11:13 PM, T799 said: What an awesome project! Will be following this one for sure. Good luck with the build mate! Thank you, seems like a never ending task at the moment as I keep finding little jobs to do! Short update since getting back; I've fitted some roll cage protection so I don't damage the paint lifting stuff in and out and later on don't damage myself it I hit the cage! Drivers door pull is also now on, and put cage protector up above my head. Hope I can't get anywhere near the top one! Need to make the rear door cards, so made up the template Need to photo the finished card but only the rear left one to do. I have found the door lock mechanism so will fit that the same as the front door. Oil System - I have the Accusump system to install but first I needed more parts so had to get a load of fitting so got some for all the other hoses at the same time. New Accusump hoses and fittings, including a one way valve to makesure the oil goes the right way back to the engine! T-piece fitting on the bulkhead runs into the car and back to the accusump reservoir. Now need the engine back in to trim the hoses connecting to the engine. Also started to make up the oil breather hose from the back of the engine. Accusump with remote opening valve and new fittings ready to install Needed to fit a cahmber for the MAP sensor so made a bracket and installed under the intake manifold. Just have to run the 4 small hoses to connect it to the intake runners Last of the bolts turned up for the engine so all the hardware has now been refreshed! Last job yesterday was installing the windscreen and side windows by bonding them in. Found a windscreen guy locally who did the job for me, although my hands are still covered in the sealant! All the bonded panels are installed like the rear quarters, rear screen and front screen. Now have to run the cables for the heating elements back so I can connect them up in the cabin 3 Quote Link to comment Share on other sites More sharing options...
Blackwolf Posted May 1, 2018 Share Posted May 1, 2018 Damn this is coming along just fine what do you use and where do you get the material for the door cards? Quote Link to comment Share on other sites More sharing options...
noodels Posted May 1, 2018 Share Posted May 1, 2018 Nearly there chap Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted May 2, 2018 Author Share Posted May 2, 2018 14 hours ago, Blackwolf said: Damn this is coming along just fine what do you use and where do you get the material for the door cards? It came from Track Day Doorcards, Simon is on Facebook and very helpful. Not sure exactly what the material is called but it came as 4 easy to cut sheets of plastic, a bag of fixings, 2 door pulls in a colour of your choice and the covers to keep it all neat. The templates tale the time to make but weren't difficult. 8 hours ago, noodels said: Nearly there chap Just loads of little jobs left to go that will all add up! Rear windows are all now bonded and bolted in. Boot lid now feels solid to close and no longer rattles and the same for the rear quarters. Plastics 4 Performance did a great job with them. Just the drivers side windows left to bolt in and the car is "sealed" Accusumo is now bolted down to the rear floor. I can now run the pipes to the bulkhead and wire in the remote control to the dashboard Rear end is taking shape, so I can start to clamp down all the hoses, pipes and cables. WIndscreen trims are also now in and looking good (apart from they need s damn good clean ). The 4 wires for the heating elements need to be routed and I thought they'd go into the cabin under the seal but I was told they need to go into the scuttle panel so I'll have to find a way to route them and wire them up. THink I've already found a way but need to check by doing it. 2 Quote Link to comment Share on other sites More sharing options...
