DC Sports 4-1 manifold issues
GreenVTi991
I bought my civic mb6 b18c4 with the exhaust already on it. It's got the above manifold which the previous owner said was from an integra. Although it fits, it is touching the sump. Is this normal? The exhaust sounds very boomy from the front - could this be caused by it touching the sump?
I'm not sure I want to keep the manifold anyway as its split a weld again. Are the Japspeed 4-2-1 manifolds any good?
  • Replies 42
Top Posters In This Topic
you need to see why is cracking tbh has it got the suport bracket fitted to chassis?welding a brace to it will help and needs to be welded with mig/tig,and not gas welded
take it to someone who knows how to correctly sort it ect :idea: if its fowling sump could tweek it with a hammer :o;)
if you are thinkng of a new one a hytec try-y 4-2--2-1/toda 4-2-1 ect would be v/good and would see gains over 4-1
japspeed 4-2-1 £180 or can get these no name ones£130 ish, will discolour thin and not as good Q as what you have atm.£300 will get you a v/good mani for good..
A cheepy will need upgrade in future :idea: save for a goodn,or s/h ;)
So 4-1 aren't as good as 4-2-1?
It did cross my mind to adjust it with a hammer but prob would do more damage than fix it!
Yes it has got a support bracket but I'm guessing its designed to fit an integra.
I will have a look at the manifolds you've suggested coz I think replacing it'll be better than keeping taking it back to my local exhaust specialists to get it fixed.
i mean a Good 4-2-2-1 or 4-2-1 is better than a medium design 4-1
really depends on what your after at end of day mid-high range Hp/torque type or high gain top end Hp the b18c4 need more mid torque in my opinion.
:idea: also i see you have inlet mods ect itr inlet? :o put pics up no idea tbh whats the best you need to get it maped :)
Quite confused as to what 4-2-2-1 is, I thought you only had 4-1 (4 pipes into 1) or 4-2-1 (4 pipes into 2 then 1), whats the other one about?? :?
really depends on what your after at end of day mid-high range Hp/torque type<4-2-1> or high gain top end Hp<4-1> the b18c4 need more mid torque in my opinion.
:lol::lol::lol:
strangely enough that does look like a integra manifold :?: is that the original B18C4 head or has someone changed it :?:
the manifold touching the sump is not a good thing. they are tight anyway. this heat will cook the oil in the engine. the B18 are slightly higher than the B16 which may suggest the mani's from a b16 but its no good for you. i recommend its changed or as noodle says twat it to clear the sump.
the two pipes pictured looks like a coolant bypass has been carried out. this basically stops the throttle plate from freezing.
hope this helps.
