Marko's MB6
marko
I can do the old bridge pins and get the code for the exact fault can't I or does it not work like that?
Yeah you can mate. You want me to find the guide for you or are you okay?
You can put it up for reference if you want shouldn't be to difficult to find with the search bar :P
How hard is it to delete the ABS?
You will need a 40/40 prop valve from a non abs honda. Guy on ek9.org sells them. Would then fit the brake pipes from the abs unit to the prop valve.
Cool, will leave it with you then chief! 8-)
hmm not as simple as i was hoping then i thought i would be able to replace the sensors with resitors and reroute the power for the light to the srs light that way itll come on and go off with the ignition and still pass mot ;D
