Re: KNK Project. photowhorish!
KiNK43
  • Replies 904
well i found the leak. looks tiny but it was enough to make a bit of a mess! you can see the bubbles between where the two pipes exit the heat exchanger...
there was congealed coolant sticky all over everything...
so to make myself happy i carbon wrapped the heater panel...
yes im tempted to solder it im a gas plumber afterall. just dont want it go again in the future. i can get a used replacement for 25 quid locally. so may just do that.
then again wont hurt to try solder it. i could pressure it up and see how it holds.
Dunno. Id imagine there's a bit.
I'll cut some copper tomorrow and try soldering the hole then solder a piece of copper over the top of it.
Just seriously don't ever want to do this again.
Does anyone know what antifreeze should go in? I had like a neon pink antifreeze from halfords in, said it was suitable for mixed metal systems. Just wondering if that's been eating away at the copper.
