civic-catch Posted September 12, 2013 Share Posted September 12, 2013 On 9/4/2013 at 9:34 PM, Roylewaa said: Cheers Paul, I've probably gotten myself chewed up for nowtA few months ago I had a Zafira, I threw loads of money into it, getting engine work done, and when I was £600 lighter it started knocking with streetfulls of blue smoke so lost on it big time when I sold itReally don't want a headache from my Civic as I went back to Honda because of their reputation and my past civics/accords giving me no grief at allthermostats on our mb2`s are left hand side of the block behind the distributor! follow bottom hose and it will bring you too the thermostat housing 2 10 mm bolts takes the housing apart and voila behold the thermostat staring at you hope this helps Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted September 12, 2013 Author Share Posted September 12, 2013 Thanks mate, yeah lad over the road pointed it out last week, I thought it was from the top hose but its notThe problem seems to have fixed itself now, the car was stood for a couple of months before I bought it so might have caused it to stick I did buy a thermostat which is in the boot, if it creeps past halfway on the gauge again I will change it straight away:) Quote Link to comment Share on other sites More sharing options...
civic-catch Posted September 12, 2013 Share Posted September 12, 2013 On 9/12/2013 at 7:24 PM, Roylewaa said: Thanks mate, yeah lad over the road pointed it out last week, I thought it was from the top hose but its notThe problem seems to have fixed itself now, the car was stood for a couple of months before I bought it so might have caused it to stickI did buy a thermostat which is in the boot, if it creeps past halfway on the gauge again I will change it straight away:)wouldnt worry bout it going to half way as my mates civic sits at half all of the time and his car is sweet. dont fix aint broke lol famous quote Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted September 12, 2013 Author Share Posted September 12, 2013 It went to just over 3/4 before I noticed it when it happened, I switched the engine straight off Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted September 12, 2013 Share Posted September 12, 2013 Strange I've had loads of hondas. And always sit at about 1/3 no matter what the conditions. Ive always been pretty on the ball with maintenance tho. Regular coolant, thermostat change etc.. But does sound like the stat if it happens again Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted September 12, 2013 Author Share Posted September 12, 2013 Theyres been no loss of coolant, apart from I overfilled the expansion bottle so it was way over the max lineSince that episode it's obviously vented the overfill and it sits on max now, or it's had an airlock and its burped itself hence the level droppingI'm not concerned as they're is no smoke, No pressuring and heaters are red hot Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted September 21, 2013 Author Share Posted September 21, 2013 Well she had another hormonal fit this afternoonDrove continuously for about an hour with no problems, then turn into my estate to come home and I literally watched the temp gauge start to climb, knocked the engine off when it went past 3/4, popped the bonnet no fans going, expansion bottle is full to the top with traces of coolant on around it and on the plastic scuttle underneath the radiator I'd already bought a new thermostat so thought might as well change it nowI've just changed the stat, old one tested and was opening, slower than the new one thoughIt was an absolute pain to bleed the system but got there in the end Ran the engine on the drive for over an hour fans kicking in now nicely My concern is the coolant is quite frothy at the rad cap and there seems to be constant bubbles, yet temp is now stable at under 1/2 Is that normal? On a plus though my heaters are now blisteringly hot, I literally can't keep my hand held over the vents Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted September 21, 2013 Share Posted September 21, 2013 Sounds like you may have a little air left in there but if the temps fine I wouldn't worry too much. There's a good how to on here for bleeding the system. Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted September 21, 2013 Author Share Posted September 21, 2013 I had the front of the car elevated and the heaters on hot with no fans onYes so far so good, only time will tell though as it was one of those annoying intermittent faultsI foolishly unplugged the temp sender which has put the eml on, doh :/ My biggest fear is head gasket failure, although surely if it was that it would overheat all of the time, this is the 2nd time in just over a month Quote Link to comment Share on other sites More sharing options...
simpo Posted September 22, 2013 Share Posted September 22, 2013 Don't worry about the head gasket mate will be fine. It was all down to the thermostat common on civics. Quote Link to comment Share on other sites More sharing options...
