KiNK43 Posted November 20, 2013 Share Posted November 20, 2013 Pop door card off. If ya got pipe cleaner arms like me get em in there with your grease and lube that sh*t up.Try window. If better pack up.If not better. Start pulling it all apart I guess Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted November 20, 2013 Share Posted November 20, 2013 You'll easily be able to tackle a couple of windows in an hour. Well assuming your quick. I can get door cards etc off in a jiffy nowadays. Maybe one window if your not so accustomed. Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 20, 2013 Author Share Posted November 20, 2013 Had the door cards off a few times now so they come off quick! Ill have a go tomorro i reckon, ill let you lads know how it goes! Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 21, 2013 Author Share Posted November 21, 2013 Just had drivers door card off... One of the rubbers hanging off lol!! Slotted back in place and silicon greased it now works a lot better! cheers lads... Do other windows tomorrow when i don't have a maccy d's waiting for me lool!! Quote Link to comment Share on other sites More sharing options...
Krzys Posted November 21, 2013 Share Posted November 21, 2013 Rubber hanging off! No wonder it was sporadic when it decided to be slow! Glad you managed to sort it without having to fork out for any parts! Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted November 21, 2013 Share Posted November 21, 2013 I do like a cheap fix. Quote Link to comment Share on other sites More sharing options...
Honda Paul Posted November 21, 2013 Share Posted November 21, 2013 If you've done it before you could do it in a hour but I'd advice u to take your time if you haven't ( nothing good ever came from rushing) If you put the window all the way down and pull the rubber out at the top then you should be able to pull each channel up from inside the door (they should just slide up) When cleaned and greased you can either remove the 2 10mm's on the window glass, pop the window out and insert the rubbers back in or as I do it - put the window half way up,grease the hell out of the inside part of the rubber (oposite side to where window glass runs) and slide the rubbers back down the same way you pulled them out. If your good then u can do all this without removing the door card at all but again that comes with practice. If the rubbers get caught then just drop the window a tad and that should pull the rubber down,then if you hold the run channel so it doesn't move and put window back up, u can then repeat this process until run channel is at the bottom of the runner. Again,hope this helps, good luck Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 21, 2013 Author Share Posted November 21, 2013 Cheers krzys, was chuffed that i dont have to fork out for motors!! And spot on nick, cant beat it! LolThanks for all the info mate!! What ive done has done the job so far but thats really good info there if anyone else may need it!!! I might even need it on my other windows!! Lol Quote Link to comment Share on other sites More sharing options...
