Krzys Posted January 17, 2014 Author Share Posted January 17, 2014 On 1/17/2014 at 3:48 PM, NIKH25 said: That sounds better. £264 is lings price, interesting to see what john banks can do them for, I saved £50 on a set of front drop links and rubbers this week. Yeah good point actually! I need a pair of fronts for mine! Link to comment Share on other sites More sharing options...
Grant Posted January 17, 2014 Share Posted January 17, 2014 On 1/17/2014 at 3:48 PM, NIKH25 said: That sounds better. £264 is lings price, interesting to see what john banks can do them for, I saved £50 on a set of front drop links and rubbers this week. What is Lings chap ?? Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Author Share Posted January 17, 2014 On 1/17/2014 at 3:57 PM, Grant-SBP- said: What is Lings chap ??Lings Honda car parts, you can order online from a main dealer but we have John Banks who look after us a bit better in the traders section Link to comment Share on other sites More sharing options...
NIKH25 Posted January 17, 2014 Share Posted January 17, 2014 http://www.lingshondaparts.com/ It's good for identifying parts, getting an idea of what it costs and then seeing how much you've saved. Link to comment Share on other sites More sharing options...
Krzys Posted January 17, 2014 Author Share Posted January 17, 2014 Didn't achieve anything, couldn't get her to fire before the battery started to lose charge, neither of my parents cars were about either so I will try again tomorrow with jump leads to boost my battery! Link to comment Share on other sites More sharing options...
ammarbm Posted January 17, 2014 Share Posted January 17, 2014 Ah mate. . You should call that person you bought it off and ask him did he ever spend a penny on maintenance of the car ever.. hopefully you will be able to sort it out soon Link to comment Share on other sites More sharing options...
KiNK43 Posted January 18, 2014 Share Posted January 18, 2014 may be worth popping injectors out as there's a little mesh filter in each one. Likely dirt caught there.Also I was quoted 15 quid per injector for ultrasonic clean. Flow test and new seals.Place in Leicester does them. Sure someone local could do same. Might be worth considering if no luck. Link to comment Share on other sites More sharing options...
Krzys Posted January 18, 2014 Author Share Posted January 18, 2014 On 1/18/2014 at 2:20 AM, KiNK43 said: may be worth popping injectors out as there's a little mesh filter in each one. Likely dirt caught there.Also I was quoted 15 quid per injector for ultrasonic clean. Flow test and new seals.Place in Leicester does them. Sure someone local could do same. Might be worth considering if no luck.Are the mesh filters easy to get to mate? Link to comment Share on other sites More sharing options...
NIKH25 Posted January 18, 2014 Share Posted January 18, 2014 On 1/18/2014 at 2:20 AM, KiNK43 said: may be worth popping injectors out as there's a little mesh filter in each one. Likely dirt caught there.Also I was quoted 15 quid per injector for ultrasonic clean. Flow test and new seals.Place in Leicester does them. Sure someone local could do same. Might be worth considering if no luck. That sounds better than new ones. Link to comment Share on other sites More sharing options...
Grant Posted January 18, 2014 Share Posted January 18, 2014 There we go, that's a much better price than new ones!! Link to comment Share on other sites More sharing options...
