When to top up engine oil?
onejdmcivic1984
Hear many diff opinions on this. Some say best to check when car cold as all will be in the sump. Heard others say when up to temp lol. I usually check after ive slapped about 50 quid of fuel in so its up to temp but had a couple of mins to settle down.
I always do it from cold the reading barely changes from hot to cold unless you check it wen youve just switched it off as there will still be oil in the top of the block so always wait at least 10 or 15 mins then check it
