Project supra
civicturbo79
  • Replies 324
I have go some jobs out of the way this week , But my to do list is just getting longer im hoping to be at the bottom of that list by the end of next week and ever thing out for welding and paint .
I start off by removing the top rad hose pipe and removing the 2 water feeds for the old turbo set up this is now being welded up .
Then a sanded off the vband off the turbo compressor side and im having a 90 degree ali pipe welded to it . i also removed and the ruff casting edges.
Then a drill and tapped the turbo hose for the waste gate pressure hose .
I port matched the manifold and turbo flanges .
Then i got the oil return line fittings and the return line made up .
Some pictures of the turbo it give you some idea of the size of it and there are some pictures with it along side of the old turbos.
Rich.
