scottravenhill Posted March 8, 2011 Share Posted March 8, 2011 is there a how to on cleaning your solenoid? Link to comment Share on other sites More sharing options...
shebabby Posted March 8, 2011 Share Posted March 8, 2011 is there a how to on cleaning your solenoid?all i did was take out the 3 ten mm bolts that hold it to the cylinder head and disconect the wire !then wen you pull it away from the head you could do with a cloth underneath to cach the oil that will run out ov it (not that much) !i didnt take the filter out ov it orifice as over time the rubber had gone hard ?i then used a full can ov degreaser spraying in all the ports and the filter untill it run clear.then just beffore i put it back on i smeared fresh oil on the rubber seal that seals it to the head !and thats it job done try to let the engine cool fully before taking the bolts out so they dont strip the threads !! Link to comment Share on other sites More sharing options...
scottravenhill Posted March 8, 2011 Share Posted March 8, 2011 knowing me i will snap the head off the bolts trying to remove them. i managed to snap 2 the other day removing the grille from the front, as i undid the plastic nuts it snapped the screw off the car. I also snapped my 1/4 to 1/8th inch socket converter trying to undo the screws for the stat. i hate working on this car its scary Link to comment Share on other sites More sharing options...
shebabby Posted March 8, 2011 Share Posted March 8, 2011 knowing me i will snap the head off the bolts trying to remove them. i managed to snap 2 the other day removing the grille from the front, as i undid the plastic nuts it snapped the screw off the car. I also snapped my 1/4 to 1/8th inch socket converter trying to undo the screws for the stat. i hate working on this car its scary the bolts on the grill break 9 times out ov 10 anyway !the best way to loosen a 10mm is with a small ratchet . that way you shouldnt put to much preassure on them .they will be tight if they havnt been off for a while ! Link to comment Share on other sites More sharing options...
scottravenhill Posted March 8, 2011 Share Posted March 8, 2011 how do you guys know if its losing oil pressure? Link to comment Share on other sites More sharing options...
johngreen537 Posted March 8, 2011 Share Posted March 8, 2011 VTEC won't kick in, and the revs will cut out early.... Especially in low gears, feels dry at the top end. Link to comment Share on other sites More sharing options...
scottravenhill Posted March 9, 2011 Share Posted March 9, 2011 What do you mean the revs cut out early? Link to comment Share on other sites More sharing options...
johngreen537 Posted March 9, 2011 Share Posted March 9, 2011 Yeah mate, or feels like its really struggling top end! Link to comment Share on other sites More sharing options...
Zuissi Posted March 16, 2011 Share Posted March 16, 2011 cheers mates!I adjusted the valve clearance today and there was at least 0.05 mm too big clearance in each valve. After the the adjustment my B18C4 is purring like a cat! There is no more lack of power at 5000-7000 rpm! Link to comment Share on other sites More sharing options...
knight Posted March 16, 2011 Share Posted March 16, 2011 cheers mates!I adjusted the valve clearance today and there was at least 0.05 mm too big clearance in each valve. After the the adjustment my B18C4 is purring like a cat! There is no more lack of power at 5000-7000 rpm! Wow!!! it made that much difference! did you get a garage to do it? got to do mine asap! Link to comment Share on other sites More sharing options...
