MC2 Project - Chassis prep
DeLaSoul
Some small jobs on the weekend, trying to complete the ECU wiring and tackled the snapped roof bar stud :angry:
Went back and started from the middle, and twisted the bundle of wires in layers.  The ends nearest the plug all had a small curl put in the wires for strain relief once the heatshrink went on
0xAi9JY-ptCM__jRmuLt24hTBGeqHgdCdnz6b9SO
Had to extend a few wires for the Lambda so a good excuse to try these new heat shrink solder joints I found online, worked pretty well and look good
m_lMM6GFgXSn0Qt_84_oaP7yWRf5towhCrPPNbzZ
Pinned the AEM puck wires in a separate shielded cable as per the other side of the loom
TMTKgIC_I4VrcCqN9OSlgeZEdX_GFCqujgOKlPeb
Want to run the loom up the bulkhead, across and out to the roll cage where the ECU will sit so did a test run first to make sure it fitted.  I've since heated and shaped the loom to fit nice and tight to the top of the fire wall to clear the extinguisher pipe
qU9blCwBZVsJEAfrJhYVKy3dmoNAw-LyXdt6o7xu
AnzS-onrHUhW8eEFsL7y9O7vgPYvQ2nHTteDZfOm
Okay, the dreaded snapped roof stud.  Had to protect the paint first with several layers of tape just in case before I drilled the stud out and through into the cabin
rA4shykOo1QcF_bX2QQ2jfUkTsLeouKN9tC7wTWM
Careful pilot hole.....
WT3WE2la1jYkAEwfb3Ny8y2dz1kQY0-gsLIzoi6_
and it comes through clear of the cage and in a easy place to work from the inside, phew!
mACVM0GaurD0foA3SQ3HUdtdU-Xsuti7CAjCkhFq
Time to drill it to size and paint the area to protect it
3HLZnhwga4mawFklx3Gb2KXtkGMHFxRx7p1xc0EE
EZ-out on the stud in the t-nut
QfRY1A-soRsU_qbogQdX_o-BgG4eNEZocf4zTSIk
-hmnbU5H9IhGbcQ5W8brihOJWLBupxs1LX7l4Txb
Back on with the end of the roof rail
wfWDEvw3HrcXRkE0jTyWM6uCcCU_CJuXVo-hIjcT
09uRX_o6iQ57LJUzhOMaCOGlcUd6lx0YW3ZlTlTf
Just the nut to paint and seal later on
uhezB2wDaNaiMWKP6j0iL7wLRRN6nyua0FbQL-t5
Will continue the wiring in the week.
Edited by DeLaSoul
  • Like 3
7 hours ago, Blackwolf said:
looking good buddy what you doing about the sunroof ?
Carbon fibre panel, just needs to be bonded in
Rs24_P85Ev6b5tT-DhnVdU2VzyKzzrRmvOD0-_z9
7 hours ago, Chandler said:
looking good mate! saw those solder joints online before and thought about giving them a try, but didn't get round to ordering any in the end
I've been meaning to try them too, had them sitting there for a while and finally gave in.  The larger ones aren't so good though, well the ones I got anyway.
