NOODELS MC2
noodels
So
after much confusion and head-scratching after fitting these cams/manifold last year regarding running rich and lean thinking the car need ecu modifications to get this corrected ie Hondata S300 and dyno testing at considerable expense <that i int got>
also fitted new pump advised by dyno testing last year or year before?FPR fitted 5 times thinking that int working as it should
Have got my thinking and arse in gear,checked a few things and found that i had fitted the Vac lines incorrectly.
From the canaster infact to FPR and creating wrong psi under loads ect.prob due to haste install of the mani.
Resulting in 10-20HP difference and a car that actually has what power with modifications is supposed to produce...
nincompoop blush.gif1
Now the car goes like f****stink..maybe  a TB 68-75mm  would help-
with max power at 8000<up from7600>
applause.gif1 Epic fail .
Was a long day wasnt the easiest of tasks getting old one removed :-D
whats the bestest bang for $ blox seem good value any good ?
BDL seems out of my price range
skunk2 Alpha keeping with the build skunk2 thing ?
70 mm being the way to go agreed :-D
I have just bought a skunk2 alpha series TB myself. Fitted it and absolutely no problems with idle etc. I can supply you a brand new one for £115 delivered.
Thanks
Do they have idle adjustment sounds good price will have to get the S taxed first though.
seems they do £120.68 with free PP on the bay also-%5 discount too :geek:
Wait until October, then you can tax the S for just a month if you wish, or 6 months at that point will no longer cost extra long term! :smile:
