my MB2 - projectors in the making - mb16
crazyrob9999
Did a little search
have you wired the MAP sensor in? Or indeed even fitted one? d15b's have it wired into the engine loom, and fitted to the throttle body, vti's have the wiring on the dash loom and it's located on the bulkhead. Without it, you wont have any spare plugs, as you're using the 'wrong' interior loom, and it will cause exactly the symptoms you're describing.
Should be a few vac lines coming out the TB that aint going anywhere if you've left it out..
Or maybe knock sensor
The plastic valve is evap purge solenoid. Connects to charcoal canister I think. If you get the PDF workshop manual from downloads section. It's shown there.
not sure about you extra connector. What's the loom from? Nice swap btw
