ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 It sounds like an aftermarket immobiliser has been chopped in to the system somehow, the only thing I can suggest is to put it back as it was. He put the wires exactly where they were soldered before, there was nothing extra there. Do you know what are those 2 plugs in the first pic that were left unplugged? One is White one is Black. Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 As above I reckon it was tapped into that ignition switch. Look at ur last pic looks like a red and black wire been chopped hunt around for some wires Also if he soldered the wires after maybe blew a fuse somewhere check all fuses and the ones under the bonnet Simpo the Red and Black wires he soldered back to where they were in the old switch. If you look at the first pic you can see its been soldered in exact place. I will check the fuses to see if any is blown out. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 22, 2014 Share Posted January 22, 2014 Also if he soldered the wires after maybe blew a fuse somewhere check all fuses and the ones under the bonnet Definitely worth checking the ecu and ecu back up fuses. He put the wires exactly where they were soldered before, there was nothing extra there. Do you know what are those 2 plugs in the first pic that were left unplugged? One is White one is Black. So it went back the way it was? I don't know what they are I'm afraid, hopefully someone will be able to help. Worth reposting in the electrical problems thread, might get more views there. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 22, 2014 Share Posted January 22, 2014 Ooooo that's weird, are those two plugs still unplugged? Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 Yeah still unplugged mate. According to the mechanic the white plug is from the transponder and the Black plug is from ecu but somehow they have been both by-passed. Don't know what the previous owner had done to it. It came with only 1 key. No red key. What does that Green light with the key sign mean? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 22, 2014 Share Posted January 22, 2014 Might be worth plugging them in? Mine came without a red key but I managed to get a working copy made! 1 Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 23, 2014 Author Share Posted January 23, 2014 Can someone find out where those two plugs are meant to go? Also Let's assume there is an after market immobiliser installed and its activated. Any ideas how to restart it? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 23, 2014 Share Posted January 23, 2014 The only other idea I have is setting it back up like it was with the old switch, but on the new one if that makes sense? Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 23, 2014 Author Share Posted January 23, 2014 We are gonna try to put the old switch back and see if they had done anything to the switch to immobilise it Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 23, 2014 Share Posted January 23, 2014 We are gonna try to put the old switch back and see if they had done anything to the switch to immobilise itYeah, if any of these extra wires were attached to the old switch you might need to attach them to the new switch so it looks like it did before. 2 Quote Link to comment Share on other sites More sharing options...
