Shawn2ace    4
I've been told that my MA8 edu is OBD2 but I haven't been able to find the OBD2 connector.
Has anyone found it or do we just not have one?
Share this post
Link to post
Finch    140
Which "OBD2 Plug" are you looking for? If you mean the diagnostic port its in the cabin on passenger side next to center console :)
If you're talking about the ECU plug, Its a bit of a farse. its a OBD2 with an OBD1 plug as far as I remember
Share this post
Link to post
KiNK43    1,544
If you talking about diagnostics connector. Some of the very late models have a 16 pin connector for scan tool.
But most simply have a 2 pin and 3 pin arrangement in the passenger footwell above the ecu.
You can buy 3 pin to 16 pin adapter cables. But how well they work I don't know.
Share this post
Link to post
Silvio    2
I have the same problem too, I cant find the diagnostic connector. I found a 3 pin connector/cable but I don't know if is the right one. Here is a photo of it, someone told me that this is the AC connector not the diagnostic. Anyone can tell me if it is or not the right one?
Share this post
Link to post
Dave    2,266
I don't think thats the diagnostic port mate (unless someone can clarify?) It should be on the passenger side of the car.
Share this post
Link to post
Silvio    2
It is a 3 pin plug, I have searched everywhere but I didn't find nothing, it is very strange...
Share this post
Link to post
d4nc00per    1
I don't know if you've checked already, but some models pre-2000 had two diagnostic ports below the dashboard on the passenger side, just above the kick plate. They should be blue in a plastic cover, one is a 5 pin ABS port and the other is a 2 pin ECU port. This is if you're car is not equipped with an OBD port.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
