Finch's Double D's
Finch
Just as things started looking up.. It all goes to sh*t again..
I broke a driveshaft on the deck' on a hill start this morning what the f**k?!
Edited by Finch
Took Apex 1hr20 to find me, got the car home found the shaft was well and truly f**ked, by the looks it's been on it's way out for a while and I just happened to be the unlucky son of a gun to find it out.
Mondeo pulled out on us on a national speed limit road. Driver in front brakes hard, I brake hard, stop, as I went to pull away after the stop I got MASSIVE wheel spin and a knocking like I've spun a rod at this point I was like "I f**king hate cars" I turned car off, turned on in neutral revved hearing no-knock thank god. In gear it knocks, first thought is clutch has gone. I stick my head under bonnet to see the above site on drivers side. F**k was exclaimed many many times this morning
1 hour ago, dr_broon said:
Seems to have been quite a few people had that happen over the years.
That does look well and truly fooked.
New one was £70, went and picked it up at 5pm having had a lift from my best friends wife, I'll be swapping that tomorrow hopefully. might be mid day before thats done. Got a fair amount of beer to drink :)
  • 3 weeks later...
The initial thoughts were to clean up the Deck' make it safe and sell it on.. I will now be keeping it instead. I am going to clean it up, do all the restorative works on it (scuffs, scratches, dents, paint peel etc fixed) and use it as a daily. I am however focusing now on Betty; The 1.4 Sport. I've started stockpiling parts for a winter build ready for the new year! Today I got a shipment from Nengun and Yesterday I had one from RHDJapan...
I'm keeping the majority of them under wraps until I can get some serious time to do all the work needed. I sent the old block off to the scrapyard however I did save the Sump and the Rocker for some work later on down the line B)
The one thing I will reveal is this...
1 hour ago, Chandler said:
bit of a s**tter the past couple of months but glad your keeping it! crap about the shaft, i had the same thing at the end of my road and thought i f**kd the engine rlol.gif1
It has been indeed - this was like a week after getting the deck so I was in a right PI5SY mood!
now I have both cars running, I will be getting them both up to Manchester in the next few weeks so I can work on the MB at night/weekends and the deck for use daily when I need a car
I'm going to start undersealing and rust treating the deck for now, then do a wing change and bonnet paint when I get a few hours. ;)
Chandler you said you'd gone ARP headstuds IIRC? Did you torque to 60ft-lb do you know?
ye man something along those lines. i read the instructions as you gotta torque em up in 3 stages
There seams to be a tonne of mixed info on the D-series. I did mine to 65 on the d16z6 I used to have, but there seems to be a load of different info :rolleyes: can't be simple like all Bs or SRs and have a single set of data!!
