dr_broon Posted January 10, 2021 Share Posted January 10, 2021 Nice to get it up and running What are you using for Bluetooth Jake? Has the coil pack kit got it? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 Tidied it all up now. Reinstalled ECU and panels but ordered a new cabin filter and heater resistor. Thaught may aswell while there. VID-20210110-WA0025.mp4 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 3 minutes ago, dr_broon said: Nice to get it up and running What are you using for Bluetooth Jake? Has the coil pack kit got it? No mate. It's a serial to Bluetooth adapter. Plugged into the cn2 connector on the ecu 1 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 Been a pain in the a*s to setup tbh. As not alot of info about doing it on the net. And trying to issue AT commands to it via USB to serial adapter been a nightmare. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted January 10, 2021 Share Posted January 10, 2021 Ah cool, is it something like this? https://www.hamotorsports.com/products/cn2-direct-ecu-bluetooth-module I've had my eye on them for a while waiting to see if my chipped p28 works - I might need to pick your brains about what you needed to do if I get the ecu sorted. They do a cable one which might be easier, but I like the idea of the Bluetooth one Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 Yes mate exactly that Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 3 minutes ago, dr_broon said: Ah cool, is it something like this? https://www.hamotorsports.com/products/cn2-direct-ecu-bluetooth-module I've had my eye on them for a while waiting to see if my chipped p28 works - I might need to pick your brains about what you needed to do if I get the ecu sorted. They do a cable one which might be easier, but I like the idea of the Bluetooth one Touch wood that will be preconfigured. You may have to have a fresh map burned for yours. As you need to enable datalogging RTP in crome and know which data logging protocol is installed. 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted January 10, 2021 Share Posted January 10, 2021 I've got a chip burner as I was trying to just put a P72 map on, but with a slightly lower Iab engagement. I think that the socket on the ecu came loose though when I was taking the chip out - I kept getting eml codes for different sensors that I kept needing to disable on crome. Last time the ecu was just dead. I've had the socket resoldered, but not been able to try it yet. I've also got a zif socket instead now to make the chip swapping easier. Don't know if I'll be able to use the burner now though, coz it used the parallel port, and my old pc with one is a long dead Windows xp box Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 10, 2021 Author Share Posted January 10, 2021 Haha yes this is where the fun starts. Because usb to serial just doesn't work like you'd expect it too. What burner have you got. A generic one or a moates? 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted January 10, 2021 Share Posted January 10, 2021 yes mate... I don't even think this works at all on usb adapters from what I've read - it's a Willem programmer... Was old fashioned when I got it then: Not even sure it runs on anything after win xp Quote Link to comment Share on other sites More sharing options...
