knight
Right mugen brace is now complete! and looking very nice if i say so myself! [smitten.gif][smitten.gif][smitten.gif]
End brackets rubbed down and 6 coat of paint applied!. Strut brace polished up! All new Bolts and washers! & Mugen decal applied! MINT! [smash.gif]
Looks good, though if it fits the same as a Mugen brace (with the stays towards the windscreen) you may want to rethink your sticker orientation ;) . With those brackets it should fit either way though I would have thought. As others have said there is no point fitting this with the Sustec brace because it does the same job only better, no point fitting it with the limited flex oem brace because this will lock out any movement anyway. I think you will have a much cleaner looking bay with just this one in it.
Its also better looking than the Mugen ones I've seen which seem to be a scuzzy plated steel finish and only bolts onto the oem fixings not the shocks which seems to be missing the point slightly.
yes you can use both ways but you need to mod to use the other way as i will come in contacted with the strut top i think?
i will only be using this brace like you said it does a better job cause of the fixing points! does 2 jobs in one! ;)
